Question about Locks & Locksmithing
I have forgotten my pre TSA number. How do I get it?
Posted by AlvinLee Miller Jr on
George Persico
    Sergeant:
  • 231 Answers
I forgotten my skybag number lock how to open the lock .
You can try to determine the combination by pulling on the shackle and moving the combination wheels until one of them clicks (or feels) different from the other numbers. Do the same for the other two number wheels. Lots of trial and error, but it has worked before.
http://traveltips.usatoday.com/unlock-threedigit-combo-master-luggage-lock-109482.html
Feb 05, 2015 | Master Lock TSA Set your Combination Lock...
Eminent luggage lock
TSA lock on Eminent Osmosis Luggage, three digit TSA lock (HOW to change it to YOUR personal number)
Put the code numbers to '000'
Take the lock levers OFF the lock
Push the round opening button UPWARDS.
IMPORTANT :
KEEP holding the button UP until you have changed the numbers
Change the TSA code numbers to what YOU want
Release the round opening button
Now your case combo lock numbers have been changed.
To lock the case put the two lock levers into the holes, spin the numbers and your case will be locked.
To UNLOCK the TSA code spin the numbers to YOUR lock code, push the lock button UP and, hey presto, your case will open.
If you forget your NEW lock number you will NEED to go through ALL the numbers, starting at '000' to '999', to be able to open the lock/case.
REMEMBER to PUSH the ROUND OPENING button UPWARDS on EVERY number change.
Only THEN, when it finds YOUR correct three digit number, will it eventually open the suitcase/luggage/baggage.
Good luck
Aug 31, 2013 | Luggage & Travel
I have a black dog TSA lock and can't remember the combination help
if you have forgotten the combo the only way to figure it out is to progress the combo starting from 000 and then 001,002,003,004 etc...( trying the lock at every new series until you get the correct combo. a 3 digit combo should only take about 10 to 20 minutes to solve. you can cut the time in half if you can remember the first number or the last number.
chris...
Sep 13, 2012 | Ultra Hardware Black Dog 55164 3 Digit...
TSA locked our TSA002 lock on our samsonite bag when they inspected it. We do not have a key. TSA said we needed to go back to the airport, but is there a way to get a key?
No. That's part of the whole purpose of TSA passkeys; they're held securely and only at ports. If it were easy for anyone else to get hold of them the locks which are TSA approved would become pointless.
You only have three options if you do not want to return to the airport:-
1. Get a locksmith;
2. Cut the lock off/drill it out;
3. If your lock is usually key operated (not a combination) then there will be a number next to the lock barrel (not the TSA number, that just tells the TSA which of their passkeys to use). A Samsonite dealer can order the correct key for you using the number and some even keep them in stock.
Oct 23, 2009 | Samsonite Tripod
Locks & Locksmithing Logo
316 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
