Question about Dryers
How do I lift the top - Dryers
Posted by LOU & SHERRY BARRESI on
Dai Boyce
    Sergeant:
  • 288 Answers
If it’s a Hotpoint or Hoover brand with a fixed lid . You info two screws on the rear and Tap the front end of the lid towards the back whilst lifting it slightly . Slowing the lid to become loose !
Posted on Dec 25, 2017
Lift will go to top and stay or down and stay with lever to top or bottom . LIFT lever half way, nothing. 6600 ford
Hydraulic tailgate lift I assume? Check fluid, check connections from lift position to valve (lever) sounds like you have a linkage problem that tells valve where the lift is (half way)?
Mar 12, 2015 | Ford Cars & Trucks
How to lift up glass top for heating element replacement.
Most of these units have a few screws underneath the top at the front lip where the top of the door closes. Remove the screws and you should be able to lift the top up. Most of them also have a metal bar you pull down or up depending on the make and model on the side to hold the top up once you open it
Mar 08, 2015 | Bosch HES435U Electric Kitchen Range
Noisy motor
All the dryers I have owned require lifting the top and then removing the front. Lifting the top requires pulling the top towards the front and then lifting up in one motion or using a putty knife to assist in the lifting the top. The front is removed with a few screws and carefully handing the wiring and drum.
Jan 10, 2014 | Indesit IS70C Electric Dryer
Lift top to access knob lights
Hello Mary Beth, I am happy to assist you!
I understand you are seeking information on how to life the top of your Frigidaire range for the above-listed model number, FGF316. Here are some simple steps you need to take:
  • Grasp the side of your cooktop and then lift from the front.
  • The top high would need to be lifted high enough to allow the support rods to snap into place. The Lift-up rods will support the top in its raised position.
  • While the cooktop is lifted up, you can use soapy water and a clean cloth, and then dry to clear underneath.
  • Lower the top gently by pushing back on each rod (when lowering the top, grasp the sides with fingertips only. Be careful not to pinch fingers). This will release the notched support. Hold the range top and slide he range top down into the range frame.
I hope this information helps to some degree. If there is anything else that I can help you with, please feel free to reconnect!
Oct 19, 2013 | Frigidaire FGF316 Gas Kitchen Range
How do i open the top of my machine?
I do not have the correct model number from the manufactures plate located on the washer, so I cannot look at the exploded parts view of you unit. I have indicated the procedure used on most top load washers which may work. You should use caution because it may not be the same style but you may be able to loosen or remove the screws from the back of the hinges to lift the top. If you can give me the correct model number I may be able to look at the diagram to give you more Ideas if this does not work.
You have clips on each side of top cabinet located in the front of the unit. If you pull the top forward and lift up you should be able free the top cover enabling you to lift the top back on its hinges. You may also use a non marring tool (wood or plastic wedge) to pry the top off while pulling the top forward. If it will not lift or you are afraid that you may damage the unit you can loosen or remove the two screws (part 34) for the hinge (part 32) in the back of the unit. You should be able to move the top forward and lift it above the retaining clips. You can replace the hinge screws so you can lift the top back on its hinge so it will not fall off when working on the unit.
Click on the link for a diagram of the parts.
http://c.searspartsdirect.com/lis_png/PLDM/K0702015-00001.png
Aug 07, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
OnyI NEED TO CHANGE THE INK ON MY PIXMA HOW DO I GO ABOUTI IT ?
You did not say which PIXMA you have and there are a number of different kinds.
Usually the top lifts up and then you can see the ink cartridges inside. Just try to lift the top up. It usually pulls up easily so lift it. It will open from the front and lift up and tilt towards the back of the printer. Once the top is open (the entire top lifts on some so try it) there will be two cartridges inside with one for color ink and another for black ink. They usually are held in by a snap on top so just lift the tops and then you should be able to lift the cartridges out. Be careful as the ink can stain.
Remember how the cartridges come out as you will install the new cartridges in the same reverse process.
Good luck......................Pete
Jul 17, 2011 | Cannon Office Equipment & Supplies
To remove 1993 mustang conv. top cylinders should top be up or down? thanks, bill
don't have 93. here's 94
Motor Assembly, Convertible Top Removal and Installation
NOTE: The folding top hydraulic cylinder rods should be in the fully retracted position.
Use absorbent rags or a container to catch any hydraulic fluid that leaks out when removing the fittings.
  1. Remove motor and pump assembly as outlined.
  1. Loosen each folding top motor upper and lower hose fitting on the sides of the folding top hydraulic lift motor and plate kit (533A00) .
  1. Remove the folding top hydraulic lift motor and plate kit .
  1. Remove each of the service folding top hydraulic lift motor and plate kit plugs one at a time and attach the tee fitting to the replacement folding top hydraulic lift motor and plate kit . NOTE: Make sure that the o-ring is installed in the bottom of each folding top hydraulic lift motor and plate kit port before attaching the hose tee fitting.
  1. Connect the folding top hydraulic lift motor and plate kit unit to a 12-volt power source and cycle the folding top hydraulic lift motor and plate kit in and out several times to purge the air from the folding top motor upper and lower hoses (53390) . Some noise squeal may be noticed due to the air. srb~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not overfill or the reservoir seal could be blown out.
  1. Carefully remove the rubber fill plug from the back and the reservoir and check the fluid level. The level should be at the bottom of the filler hole. If necessary, add Synthetic Mercon® Multi-Purpose Automatic transmission fluid E6AZ-19582-B (ESR-M2C163-A2) or equivalent.
  1. Replace the fill plug with a new fill plug.
  1. To install, reverse Removal procedure.
Section 01-17: Convertible 1994 Mustang. Workshop Manual
REMOVAL AND INSTALLATION Lift Cylinder, Power Top Removal and Installation
NOTE: The cylinder rods should be in the fully-retracted position.
  1. Remove pump and motor as outlined.
  1. Remove the upper and lower hose fitting from the folding top hydraulic cylinder (50600) . Use absorbent rags or a container to catch any hydraulic fluid that leaks out when removing the fittings.
  1. Remove each of the service cylinder plugs one at a time and attach the hose fittings. NOTE: Be sure each fitting is installed in the correct position on the folding top hydraulic cylinder .
    NOTE: Make sure that the tetra seal is installed in the bottom of each of the folding top hydraulic cylinder ports before attaching the upper and lower hose fittings.
  1. Connect the folding top hydraulic lift motor and plate kit (533A00) to a 12-volt power source and cycle the folding top hydraulic lift motor and plate kit in and out several times to purge the air from the hoses. Some noise squeal may be noticed due to the air.
Jan 21, 2011 | Ford Mustang Cars & Trucks
Problem lifting cartridge lid on model dx7400
There's a small "latch" that holds the top of the lid "down". Push to release the latch, and then you can lift the lid, using the "hinge".
Jan 14, 2010 | Epson Stylus C86 InkJet Printer
Cant remove top of front loading washer
Remove the four screws at the top rear of the top panel that go through the hinge brackets(bare metal in color), then lift up the top panel and push toward the front of the washer while lifting, it may take a firm lift and push, work with it and observe how the top and sides are connected once you have lifted the rear of the top panel. Good luck !
Jan 09, 2010 | Hotpoint WMA58 Front Load Washer
How do you open top to access squeeking belt
Remove two screws under lint door. Take and brace the front of the dryer while pulling forward on the right side of the top and lift. Then do the left side forward and lift. There will be a screw on each side of the cabinet once the top is lifted. The front will then come forward, lift and remove. Chances are the belt tension-er, which is referred to as an idler is bad.
Sep 21, 2009 | KitchenAid KGYS850LT Gas Dryer
Dryers Logo
Top Dryers Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
