Question about Maytag Refrigerators
Just purchased Maytag a fridge icemaker water dispencer.water is warm had fridge for 2 weeks..
Posted by Digno de jesus... on
David Emmel
    Sergeant:
  • 295 Answers
Contact the dealer for warranty repair at no charge.
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Posted on Jan 02, 2018
5 Related Answers
douglas smith
  • 1462 Answers
SOURCE: Maytag side by side model GS24C8C3EV Refrigerator too warm
it is almost certainly a defrost problem. when fault has occured, remove freezer bzck panel and see if there is ice build-up. if so this confirms a defrost problem - possibly that the element is open circuit
Posted on Jun 22, 2007
Anonymous
  • 120 Answers
SOURCE: Ice will not dispense GE model GSL25IFRF BS
well if you trouble shoot the board at the back to see if you are getting voltage if you are then use a jumper on that conenctor and see if the auger motor runs or remove auger motor and check voltage there while pressing the lever for ice usually 100% of the time that board controls everyhting water and ice
Posted on Nov 18, 2008
gtaplytmpt
Andy
  • 90 Answers
SOURCE: icemaker
Do you hear it trying to draw water into the ice tray? If so, there might be an internal problem you can't fix yourself. especially since the fridge is dispencing water. Is the arm inside the ice maker pushe down? This is what tells the ice maker to fill and make the ice.
Let me know if this helps.
Posted on Jan 02, 2009
Joe Povoas
  • 111 Answers
SOURCE: water pooling on bottom of freezer and leaking into fridgerator
in the back of the fridge you have a hose going to the bottom , take everything from inside of the fresh food compartment and blow in the hose and after voila problem solved
Posted on Jun 18, 2009
Anonymous
SOURCE: maytag fridge no water to icemaker any suggestions
Our ice maker stopped working due to lack of a water supply. We noticed a discoloration of the wood kick panel at the floor of our kitchen cabinets next to the refridgerator. It turns out that over the years (10 or so) the plastic water supply line had become brittle and cracked, thus allowing a slow leak, which rotted the kick panel. The brittle portion of the plastic supply line was replaced, and now the ice maker works properly with no leaking.
Posted on Sep 21, 2009
No water from the Icemaker and Water Dispenser Dual Inlet Valve
if no water is going to both icemaker and water dispencer, check water supply to refrig. into valve.
If ok and valve is being energized by dispencer arm and icemaker, then it's probably a bad water valve
Dec 03, 2011 | Whirlpool Refrigerators
Fridge will not make ice
This happens on my Sub Zero. I turn the whole fridge off for 30 seconds and this resets the teeny-weeny "brain" on the ice maker. Simple and can't hurt to try.....
May 01, 2010 | Kenmore Refrigerators
How to defrost the water line coming into the icemaker? The water line that goes from the fridge to the freezer is frozen and the icemaker does not have water to make ice and the water dispencer does not...
Good day,
The machine has problems and they hve to be addressed.
The machine needs to be shut off, and the food moved.
I do not recommend using a hair dryer since it can melt things you never want to melt.(Those components are plastic and vinyl).
The DUAL WATER VALVE in the bottom back of the machine, needs replaced at the same time, since it's the cause of your problems.
As well, the line to the water outlet could be frozen, which means defrosting the freezer door completely.
Looking at a 12 hour minimum off time, with the machine unplugged.
Using a floor fan blowing into the freezer compartment will reduce that time to approx. 8 hours.
Dec 29, 2009 | Kenmore 57029 Side by Side Refrigerator
Maytag fridge has constant running water sound
you hear a constant running water sound? look in your manual under "normal operating sounds". it explains all of the sounds. it sounds like you're hearing the refrigerant going thru your evap. coil located behind the rear frzr panel. you unit goes into the defrost cycle roughly every 8hrs and water drip down into the condensate pan un the refrig.
Jul 16, 2009 | Maytag MSD2756GES Side by Side...
Icemaker
Jan 02, 2009 | Frigidaire FRS266ZDSB Side by Side...
Icemaker not working
mike you might have a frozen fill tube check for that also are you getting wtr ook at the dispencer if you dont recheck water supply again
Oct 13, 2008 | Whirlpool ED2FHEXN Side by Side...
Icemaker and water dispenser not working GE GSS25JFPA stopped working and i thought it was water filters (have not changed in 4 years changed the internal filter and a aux one in basement in line no...
generic troubleshooting video: http://gei.portals.streamos.com/cc/channel.php?emcid=1416&empid=4533&packageid=0000
as the video shows a kinked line may be the culprit. or
if your ice maker is making ice and it is your ice dispencer that is not working along with your water dispencer and when you press the dispencer button the light dims on the door. I would replace the main board. I experienced the same problem and the board fixed it This board is shared by many models and brands of fridges and the transformer goes bad from power surges this board powers the solenoid valves that open for your water
Apr 03, 2008 | Refrigerators
Maytag MFD2561HES
Texas, sounds like your water reservoir is frozen up. Remove your 2 cripser drawers, you will see the reservoir behind them. Take a hair dryer and go over the tank and tubing ends. See if the water starts flowing. I find a lot of frozen water reservoirs on these french door models. They have a insulation kit for them. Catriver.
Sep 29, 2007 | Maytag MFD2561HE Stainless Steel Bottom...
Refrigerators Logo
Top Maytag Refrigerators Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
