Computers & Internet Logo
Jack Childress Posted on Dec 25, 2017
How do I rename my alexa - Computers & Internet
Why is my Alexa isn't discovering devices?
Your Smart device is not compatible with the Amazon Alexa device
Smart Device is not connected with same Wi-Fi network
Alexa Device Firmware not updated
Alexa Skill did not update or Added
Amazon Alexa not mention or add the Rename your Device
Read more: Alexa Not Discovering Devices
Alexa Drop In
Why is my Alexa Not Turning On Today?
Many reason for Alexa won't turn on:-
Your power outlet is faulty
Power adaptor of Alexa is damge
Alexa device is not fully Plugged-in
Alexa speaker power port is the dirty
Alexa App not update
Alexa firmware is not update
Alexa internet not working (Alexa Won't Connect to Wi-Fi)
Alexa Skill not update
Above the requirement check and get your Alexa is turning on mode. If still there problem on Alexa Won't Turn On then need to talk with expert.
Why My Alexa Routines Not Working Today?
Alexa Routines Not Working Due to
Routine is not written correctly right work
Internet connection not working when we connect with Alexa smart device
Alexa voice not working
Sometime Alexa is connecting with all routines
Alexa routine is disable mode
Alexa routines setting issues during When we connect Alexa and home smart device through Alexa App
How to Fix:
Need to check the Routine is written correctly
Need to check with say the Tigger words
Check the Alexa Echo is connect to Routine
Check the Sensor, voice commands, Alarm, etc are working condition mode
Need to delete or reinstall the Routine
Need to reset the Alexa Echo routine or device
Need to contact with Alexa expert today because they will resolve Alexa routine not working problem at a time. They will Also resolve the smart Alexa issues such as
Alexa Offline
Amazon Echo Registration Failure
Alexa Having Trouble Understanding
Alexa won't Connect to fire TV
Echo won't connect to Amazon music
What types of Alexa issues?
Different types of Alexa Issues are here mention below:
Amazon Echo Setup installation
Alexa Echo registration failure Error
Alexa ring issues such as Alexa red ring, white ring, Alexa blue ring, Alexa green ring, Alexa purple ring etc.
Trouble Setting Up Echo problem
Alexa Echo Offline issues
Alexa Echo dot Offline issues
Alexa Echo show Offline problem
Echo Goes offline problem
Echo Not Responding error
Echo Won't Turn ON error
Echo Dot Won't Turn ON error
Alexa not connecting to Fire TV problem
These are the Alexa related issues, you can contact Alexa customer service number and get the instant solution!
What are the types of Alexa issues?
We know Alexa is the most popular and famous smart speaker device. But sometime many user facing the Alexa issues as follow
Alexa is Offline issues
Alexa Won't connect to Wi-Fi problem
Alexa registration Failure issues
Alexa not responding issues
Alexa Ring Light Issues
How To Set Up Alexa
And many other issues also arise during the Alexa connectivity with home smart device
Alexa installation
Alexa update
Alexa not working
Alexa not show light
Alexa not say anything
When these issues arise then you need to solve them by the latest method. So contact us and get the best solution!
2answers
I am having trouble connecting to Echo plus. I get to the discover device but then the Alexa app says no device discovered. What can I try?
Compatibility
The Alexa app is available on:
  • Fire OS 5.3.3 or higher
  • Android 5.1 or higher
  • iOS 10.0 or higher
  • Desktop browsers by going to: https://alexa.amazon.com
Download
Go to the app store on your mobile device and search for "Alexa app."
Note: The Alexa app downloads automatically to Alexa-enabled Fire tablets. To learn more, go to Using Alexa on Your Fire Tablet.
Update
To check for updates, go to the app store on your mobile device and search for "Alexa app." If an update is available, tap the Update button. If you don't see the Update button, you're on the latest version of the Alexa app.
To learn how to use the app, go to Amazon Alexa App Basics.
Alexa is telling me she is having trouble understand right now. Try again later.
If your Alexa says "Alexa Having trouble understanding right now", then you need to troubleshoot the Alexa device.
5 ways to try to fix it
If Alexa having trouble understanding issues arise then you need to shutdown Alexa for a few minutes and after restart the Alexa Device.
Unplug the Echo Device and Plug after few minute
Make sure Alexa is connected to the internet.
Also check the Alexa App's update condition.
If Above all fails then you need to try to fully reset the Alexa Echo device.
Some time Alexa not responding issues arise then you then contact Alexa Helpline, they will resolve the Alexa related problem within a minute.
Grand Canyon Tech
Grand Canyon Tech
