Question about Coby Audio Players & Recorders
I have a Coby dvd-288. How do I get it to resume where I left off after I turn the player off?
Posted by Arnold Spinka on
1 Related Answer
Anonymous
  • 36 Answers
SOURCE: I need a Universal Remote Code for Coby DVD-288
http://esupport.sony.com/US/perl/model-remote.pl?mdl=RMV310
this a link to there web site for the remote as far as i see the remote will not work with the dvd player.
Posted on Jul 13, 2009
Coby dvd-277 not responding
Here is how to unlock:
  1. Press SETUP
  2. Press VOL+, VOL-, VOL+, VOL-
  3. Current RC should be displayed
  4. Select the RC with RIGHT and LEFT (255=Codefree)
  5. Press SETUP
  6. Turn the player off
I have a PHILIPS DVP3962. My DVD player used to play where I left off watching my DVDs, but recently, when I turn it off and turn it back on, it starts from the beginning of the DVD. Dose anybody know why...
Resume function is wiped from the player's memory buffer whenever the unit is switched to standby (either with the [POWER] button on the main unit, the remote or turned off at the wall), the disc is removed, or the [STOP] button is pressed twice (either on the front or via the remote).
(The simplest thing you can try is to insert a DVD, play a few minutes of its main title, press [STOP] once, not twice, leave it for 10 minutes, then press [PLAY] - it should resume, and thus continue your movie from where you left off)
Resume is considered 'temporary memory' in DVD devices, and therefore is not intended to store the playback point of the disc permanently whenever power is lost, [STOP] is pressed twice or discs are ejected.
However, this is relatively normal, and is not a fault, but it can be annoying to the user.
Where can i find a power cord for my dvd player pdv-288
try amozon web site you will need model number of dvd player that is on bottom of dvd
1helpful
How can I find/reset passwords on Coby 224S and Coby 206
http://www.dvddemystifiziert.de/codefree_en/coby.html
Unfortunately, I don't see Coby 206. There is a 207 however if that would work.
Unlock Coby DVD players - DVD hack
Coby DVD-201 / DVD-217 / DVD-224 / DVD-227 / DVD-237 / DVD-505 / DVD-514 / DVD-527
  1. Press SETUP
  5. Press SETUP
Coby DVD-202 / DVD-203 / DVD-207 / DVD-208 / DVD-218 / DVD-507 / DVD-508 / DVD-606 / DVD-615
  1. Method 1:
  2. Press SETUP
  3. Press 2, 1, 8, 8
  4. A new menu entry appears (Version)
  5. Select it
  6. Press ENTER
  7. Select "Region" with RIGHT
  8. Select RC with UP, DOWN (0 = codefree)
  9. Press SETUP
  10. Turn the player off
  1. Method 2:
  2. Press SETUP
  3. Press VOL+, VOL-, VOL+, VOL-
  4. Current RC should be displayed
  5. Select the RC with RIGHT and LEFT (255=Codefree)
  6. Press SETUP
  7. Turn the player off
1helpful
1helpful
3answers
Portable dvd player
I found one for my PDV-288 at www.techexcess.net at a very good price. Now I just need to find a source for a new rechargeable battery.....
Blob on screen
You will need to replace the screen to remedy this situation. The screen has been stressed somehow, and is broken internally...accordianman
Coby DVD-206
d653e9c.jpgThis is a photo of the
Coby DVD 206 and the Gold area after the T in About is the part you may try to move to the left towards the word Talking and then move it back towards where mine is located now. I was also wondering I need a Manual for the Coby DVD 206 is there any way you could may be scan yours and save it as a PDF and email it to me
@ [email protected] I would greatly appreciate it and I hope this fixes your
problem. Thanks macman60
1helpful
Region
coby 514.
power up. put disc in tray
press set up
then vol+ vol- vol+ vol-
code appears in top right 1
change altering left and right buttons
leave on 255 multi region (all discs)
press set up.
Coby DVD-514M
Turn unit on with remote
NO DVD in the tray (mine was closed, but opened might work)
Press TITLE then 1 then 9
Gray box will appear in the center of the screen with number 1 in the middle
Using up/down arrows change to desired region (0 for REGION FREE)
Top Coby Audio Players & Recorders Experts
Jean Sintulaire
Ekse
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
