My GE top loading washer continues to fill while lid is up for loading.
GE Model GTWN4250M1WS
Bill Boyd
    Top Expert:
  • Washing Mach... Master
  • 53,816 Answers
Fix the safety switch for the lid
all operations are to stop when the lid is opened
Posted on Dec 24, 2017
Testimonial: "Thanks for the quick answer. The water continues but the alarm continues to sound. I will try your suggestion."
5 Related Answers
Anonymous
  • 878 Answers
SOURCE: replacing lid switch
someone, Im not finding that model number. Going by the first six digits Im assuming that this is a regular top loader and not an Oasis washer. If so, remove the end caps on the consol by pulling them off. Remove the screws under each end cap and flip the consol up. Unplug the lid switch connector and snap springs holding the cabinet on. The whole cabinet will pull forward and you can get at the lid switch. Check out the pics and post back...Catriver.
Posted on Apr 15, 2007
chris weier
  • 82 Answers
SOURCE: Washer only spins
Have you tried to unplug the machine, sometimes the control boards can get stuck and if you unplug it for say 30 seconds then plug it back in, it may reset itself. otherwise you may have to call someone these are very complicated machines.
Posted on Jun 19, 2009
Anonymous
  • 5 Answers
SOURCE: GE front load washer model #WBVH6240FWW leaks when
Check the big rubber seal around the door for any holes or tears. Had the same problem, my husband had a screw in his pocket that torn a hole in the gasket.
Posted on Sep 27, 2009
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: GE top load Profile washer. Spin cycle not
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on Jun 12, 2010
Anonymous
SOURCE: GE Profile WPRE6100G Top Load Washer how do you
worst washer I ever owned how do you bypass water level so you can wash a comforter man I am so disappointed with this GE Profile energy saver if I can't move the water level up I'm going to put it out along the road a trash day and it's only 4 months old
Posted on Dec 26, 2010
2answers
My ge top load washer wont start already change out board. not sure if my lid switch or magnet is bad?
Sure does sound like your safety switch isnt working. To be sure please give me model number to unit and I can do some checking and get right back to you
I have a model WJRE5550H1WW washer that will fill agitate but will not pump out and spin
first check the lid switch, a lot of washers will agitate with the lid open but wont spin out. If its not that check your timer and then your water pump. Most likey it is the lid switch.
The washer will fill up and drain, but no agitation or spin.
The lid switch must be checked for continuity. On this model the lid switch must be good to agitate and spin.
GE top load washer will fill, but won't drain, spin, or agitate
Sounds to me like its just a lid switch issue. The washer needs to know that the lid is shut beforeit will advance. A model # would help. Its a basic fix and shouldnt be too expensive. Certinly chepaer than a new one. Hope that helps. Dave www.washermd.com
Washing machine fills, but won't agitate
maytag washer dryer stack unit , model # lse7806ace washer fills with water but won't agitate or do anything else. I had the same problem a year ago and replace the lid switch asssemby and fuse and it worked fine until now. the switch clicks when I open and close the lid and the pink and orange wires show continuity with the lid closed.
Pos ge washer WCSR2080B
Sounds like u might be having trouble with the lid switch.. U need to also check you water pump out.. this model has a electric pump that may be plugged... dont take much to plug this pump up.. have you taken front panel off yet ? Post what ya find
Washing Machines Logo
Top Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
