Question about Boating
Can I plug the wiring harness from my 2003 Suzuki df15 4 stroke remote outboard engine into my old 1998 Suzuki df15 4 stroke remote engines wiring harness without causing damage to the newer engine?
I have recently replaced my 1998 df15 Suzuki remote outboard engine, port side gear/throttle gear change with a 2003 df15 Suzuki remote but has a stbd. side gear/throttle gear change. As the wiring harness on both engines has similar male/female plug can I simply new into old?
Posted by peter pugh on
Fabrice Wolters
    Sergeant:
  • 331 Answers
Yes,
The basic circuitry is identical for identical connectors.
Additional harnesses are avalaible for newer dashboards etc...
Posted on Dec 26, 2017
5 Related Answers
Anonymous
SOURCE: 1994 Audi Quattro 90 engine wiring harness to TPS
If you want a good selection id try a parts locator. One place that can find you a good short or long block for a [URL="http://www.texas-junkyards.com"]Audi A4 engine[/URL] is [url=http://www.texas-junkyards.com]TEXAS Junkyards[/url], Junk Yards in TEXAS TX salvage recycler. They have a link somehow to multiples of thousands of recycling centers and will locate the best one for you.
Posted on Jul 16, 2008
Anonymous
SOURCE: What do u mean by
I had the exact same problem described here. Here's the full details:
I was driving home from work when the car just died on the freeway. I'm about 90% convinced that when it did, the green key light in the dash flashed 3 times, just like when you remove the key from the car. Restarting the car on the freeway worked fine. When I got home and shifted into park, the car died again. When I tried to restart, it started up just fine, but died within about 1 second. I tried this several times. I went in the house to get organized, then came back out to troubleshoot. I had it in my mind that it might be related to the key, given the key light flashing. I fiddled with the key and noticed the dashboard light flickering. I continued playing with the key, and pretty soon couldn't reproduce the problem.
Thinking that the problem was "fixed" by my fiddling with the key, I took the car out again. About 15 minutes into my trip, going 65MPH on the freeway, the car freaked out. A few dash lights came on (I think including the key light) and the gauges (speed/RPMs) went full for an instant. ...then, the car recovered. I pulled over. When I tried to start the car, I again got the symptom where it would die after about 1 second. Finally, I was able to start the car and went home.
I took the car to a local mechanic who specializes in Honda. He couldn't find anything wrong and couldn't reproduce the problem. Did the same with the local Honda dealership. Same thing. Both were very nice and didn't charge me for this and said to come back when the problem was happening more often. That scared me, since having a car die on the freeway is very dangerous!
I did my research and found this (and similar) stories. ...even though my records indicate that the recall was fixed in my car years ago during a routine maintenance, I was convinced that I was experiencing the problem now (with 115K miles on my 1999 Honda Accord). I took it into the dealer and insisted that they replace the part, even though they couldn't diagnose anything. They did, charging me $166.31. I also asked them to look at signs of failure in the old part.
When I picked up the car, the dealership gave me the old part, and pointed to some melted solder on it, indicating that in the past it probably got really hot. He thought I might have been right that this was the failing part. I took the part home and opened it up. On the inside, I see burnt plastic under the melted solder. Clearly the part had been sparking, which heated it up and melted the solder. I'll try to attach pictures.
I'm not sure why my part is failing, but best guesses are that one of these three things happened:
1. The part was never replaced, even though it says so on my record. This could have been because the dealer / mechanic was lazy, or it could have been an honest mistake.
2. The part was replaced, but was replaced with the wrong part. The dealer might have had a box of old (defective) parts lying around and replaced my part with one of those. Again, this could have been on purpose, or an honest mistake.
3. The new part is also defective.
I'm currently in the process of trying to get Honda to pay for this under the recall 02V120000.
Anyway, hopefully this email will help others.
Hopefully you can see from this picture, but the solder on the upper-left joint is all wrong as if it's been melted...
Here's the inside of the switch. Note the blacked plastic. This isn't black grease--it's actually burned plastic!
-Doug
Posted on Feb 02, 2009
Corey Daniels
  • 14 Answers
SOURCE: 1987 Suzuki Samurai alternator wiring. No original wire harness
yes the b goes to the battery.
http://bbs.zuwharrie.com
heres the site for you.. we have all the answers.
http://www.acksfaq.com/diagram_color_86-88_sam.htm
i drew this up a while back. it could help you out alot.
Posted on Apr 22, 2009
mxcaltrz
Luqman Khan
  • 20 Answers
SOURCE: diagnose 'check engine' warning alarm
might be some electrical problem, because, Suzukis are mostly controlled Electronically, it may represent a malfunction!!
try contacting an electrition!!
Posted on May 08, 2009
Anonymous
  • 1985 Answers
SOURCE: 2000 ford super duty 7.3 diesel will not cold start
you need to have the engine coolant switch checked,since the computer relies solely on sensors,the ect tells the computer how cold or hot it is so the computer will make it a rich or lean mixture to start the engine,if it tells the computer that it is 75 degrees the computer will lean the mixture like starting a car in the winter without a choke.
Posted on Jan 06, 2010
2010 150 Evinrude E-Tech. Motor was running great then just shut off. Will not start again.Could it be it needes to be reset, all 4 lights at tach light up showing good.
first bit of advice
do not use e-mix fuels in outboard engines
WHY
because ethanol separates from the fuel if not used continuously so letting it stand between outings is not good
secondly ethanol is hygroscopic which means that it absorbs moisture from the air that is going in via the tank vent and that results in corroded aluminium parts and rusted fuel tanks and outboards operate in a very moisture laden environment
now for the problem
being a late model engine , it should be a 4 stroke and like any 4 stroke engine , check the timing belt/chain, crank/cam position sensors , ignition module
it is important to check all harness connections as salt water rapidly causes corrosion in electrical connections and components
have the service agent do a scan for fault codes remember this
Suzuki out board 2 stroke motors were used in the early suzuki 4x4 cars and modern 4 stroke engines are simply car engines on end
Sep 18, 2017 | Clymer Evinrude/Johnson 5-70 Hp...
I need a manual for my 4 stroke 100HP Susuki outboard
Frans, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
suzuki 100 hp outboard specifications Google Search
Suzuki
https://www.tradebit.com/filedetail.php/142965517-suzuki-outboard-service-manual-df90-100-115
May 02, 2016 | Boating
Do I use reg gas or a gas mix?
Matt, If engine is two stroke and not oil injected then yes you must mix 2 stroke oil and fuel. 4 stroke engine have a crank case which is filled to proper level with 4 stroke engine oil. Check the attached links,instruction and guides, Good luck
How to Decide Between Two or Four Stroke Outboard Boat Engine
4 Stroke Outboard Motor vs 2 Stroke Outboards
2 stroke outboard Vrs 4 stroke outboard
http://www.cottagetips.com/tips/boat-motor-gas-to-oil-ratios
Apr 15, 2016 | Boating
I have a 140 Suzuki 4 stroke and a small oil leak.. where are the coolant lines in the engine please
go google and type in--- workshop manual for suzuki 140 hp 4 stroke outboard and there are manuals that are available on different site
the manuals will show where the lines are
one site --servicemanualspro.info--- has a pdf down load link
Dec 02, 2015 | Boating
1988 w/2003 engine. How do I connect new harness?
WOW?
yes, the new ECU;PCM uses a real electronic 3 wire
hall sensor for speed, (or uses ABS if opted)
swaps are complex. we need
what you had before the swap (drive line)
and what was removed from the 2003... every part.
http://www.jeep4x4center.com/knowledge-base/index.htm?utm_source=cj#service
Aug 26, 2015 | Jeep Wrangler Cars & Trucks
Are the controls for a 1998 15 HP 2 stroke Mercury outboard compatible with a 2011 30 HP 4 stroke Mercury outboard
If your old engine/control has the same 'options' as the30hp, yes everything is compatible... (Electric start or trim )
The throttle and shift cables are allways compatible...
Jun 25, 2015 | Mercury Marine 15hp & 20hp 4 Stroke...
What is the yamaha spark gap for jet ski engines 1990 year
0.024
http://www.globaldenso.com/cgi-bin/global/plug/usa/pw/pw-plug.cgi?filename=pw-14.txt
Sep 01, 2014 | Clymer Yahama 2-250 HP Two-Stroke Outboard...
Boating Logo
88 people viewed this question
Top Boating Experts
ray gallant
Andrew Taylor
Andrew Taylor
Bill Boyd
Are you a Boating Expert? Answer questions, earn points and help others
