Question about Maytag Refrigerators
SOURCE: Maytag Refrigerator Ice Maker
The
refrigerator has a duel water valve, one for the ice-maker and one
for the water dispenser (if equipped). The valve that
the ice-maker relies on may be bad, or it could be the ice-maker itself.
Another thing that could cause it would be
the temperatures in the freezer. The ice-maker will not
call for water until it reaches under 15 degrees. In addition, check
the water tube behind the ice-maker to make sure it is not frozen, blocking
more water from entering. The water does not go to the ice-maker or
thru the filter unless the ice-maker turns on the water valve.
Posted on Jul 04, 2008
SOURCE: Ice maker removal
first of all remove the ice bucket. then you will see a wiring cover on teh left hand wall just below teh icemaket. there is a rectangular hole in this cover. using a small precision scredriver carefullly insert into this hole and push up or and down to release a hidden clip. the trick is to pull on the wiring cover while you try to maneuver the clip. first time you do it it can be very frustrating but keep working at it and you will get it.
alternately you could just leave the Icemaker in place and use a hairdryer to melt the jammed ie out of the way. good luck peyton
Posted on Jan 28, 2009
SOURCE: Maytag MFI2568AES Stainless Steel Bottom
sounds as if the icemaker is getting too much water and causing the unit to flood out. aside from replacing the icemaker you may be able to adj the amount of water going into the icemaker. there is a screw that holds the front cover of the icemaker inplace. remove the cover and you should see a screw with a + and - sign on it. try turning the screw 1/4 turn then wait for the icemaker to cycle and see if it improves. keep making theses adjustments until your problem is solved thx peyton
SOURCE: my maytag refrigerator sidebyside ice maker stop working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
mnc
Posted on Sep 30, 2010
Sep 24, 2015 | Maytag MFI2568AES Stainless Steel Bottom...
May 25, 2013 | Maytag MFI2568AES Stainless Steel Bottom...
heatman101
Feb 14, 2011 | Maytag MFI2568AES Stainless Steel Bottom...
Oct 16, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
Oct 10, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
Sep 07, 2010 | Maytag MFI2568AE Side by Side French Door...
Jun 14, 2010 | Maytag MFI2568AE Side by Side French Door...
Apr 24, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
Jul 05, 2009 | Maytag MFI2568AE Side by Side French Door...
Jun 20, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
848 people viewed this question
