Question about Panasonic Cameras
Panasonic Dmc-S1 camera how to retrieve date and time from the sd card
5 Related Answers
Anonymous
SOURCE: Panasonic DMC-FX-7 Software
Follow this link
http://www2.panasonic.com/consumer-electronics/support/Cameras-Camcorders/Digital-Cameras/Lumix-Digital-Cameras/model.DMC-FX7K
Posted on May 23, 2008
Anonymous
SOURCE: Can I use a SDHC card in my Panasonic DMC-TZ1
According to the TZ1 manual the maximum size of SD hard is 2gb. You cannot use the new format SDHC card as it is not recognized.
Posted on Dec 05, 2009
Dennis Maeder
  • 257 Answers
SOURCE: None of my SD cards (I have 4) will work with my panasonic lumix
This camera uses the SD standard - not SD HC.
Be sure you are using a compatible card!
The highest capacity mentioned in the manual is 1GB althought the SD stanard supports up to 4GB.
Posted on Dec 14, 2009
drifterK
Catalin Turcu
  • 4924 Answers
SOURCE: HOW DO I FORMAT AN SD CARD FOR MY PANASONIC LUMIX
be sure it is not blocked. (it has a locking button on the side) and after that into the menu of the camera look for format reset card ...this is the best way to do it cause it will format it on the way camera will support it ...Beware cause this will delete all your pictures..
usually the format feature will be on the view picture mode...around the option for delete single or multiple picks..
but if this is too hard ..just nsert the card into a card reader in a laptop or computer ...go to my computer folder...it will be seen as a removable storage device ..click right on it ..and than format ...choose to format in fat 32 not in ntfs cause the camera may not read it after that ..
so ...fat or fat 32 will be the mode...and if you have patience do not do it in the quick mode..cause it may cause damages in the long term ..(after a few times)
Posted on Apr 17, 2010
Anonymous
  • 1901 Answers
SOURCE: Should you use an 8gb sd memory card in a
The manual lists the following SD cards compatible:
4 GB SDHC Memory Card
2 GB SD Memory Card
1 GB SD Memory Card
512 MB SD Memory Card
256 MB SD Memory Card
128 MB SD Memory Card
64 MB SD Memory Card
An 8GB card may or may not work. If you try it, make sure it is an SDHC card. (Note: HC=High Capacity)
Thanks for using Fixya.
Posted on Apr 27, 2010
What is the max sd card size for a panasonic lumix dmc-fh22
SD cards max out at 2GB. However you may also use SDHC cards, which max out at 32GB, or 64GB SDXC cards.
Dec 04, 2012 | Panasonic Lumix DMC-FH22 / DMC-FS33...
Should you use an 8gb sd memory card in a panasonic lumix dmc-fx3 camera ?
2 GB SD Memory Card
1 GB SD Memory Card
Apr 27, 2010 | Panasonic Lumix DMC-FX3 Digital Camera
Panasonic DMC--LZ2 gives me ''memory card error'' message if i put a SanDisk SDHC 4GB card in.
The DMC-LZ2 is specified to work with SD cards, not SDHC cards. While SDHC cards are physically compatible with SD cards, they will not work in SD devices. SD cards will work in SDHC devices, but that doesn't help you any here.
It's a hardware incompatibility. No firmware update can get around it.
Apr 05, 2010 | Panasonic Lumix DMC-LZ2 Digital Camera
I am unable to un-protect the memory card on my panasonic DMC=LZ5 camera. The same card had been in the camera and in use and suddenly it became protected. How do I get it back to normal (unprotected)?
The manual for Panasonic DMCLZ5 [ date: 20060223 ]
http://dlc.panasonic-europe-service.com/EUDocs/GetDoc.aspx?did=140225&fmt=PDF&lang=en&src=3&uilang=nl-NL&model=DMCLZ5
When you are using a
SD Memory Card
•On this unit, you can use SD Memory
Cards of the following capacity (from 8 MB
to 2 GB).
The SD Memory
Card is equipped with a Write-Protect
switch E that can inhibit writing and
formatting a card. (When the switch is slid
to the [LOCK] side, it is not possible to
write or delete data on the card and
format it. When the switch is unlocked,
these functions become available.)
Aug 01, 2009 | Panasonic Lumix DMC-LZ5 Digital Camera
Panasonic lumix dmc-tz1 SD card - card reader
My guess is either the cardreader or its driver is outdated. Search for the latest driver for this reader, as well as others with a similar problem as your, on the internet. The reader itself may also be hardware defective.
You can get a very good, but dated, laptop with USBs on ebay at a good price. The other alternative, if you have a dated laptop, then you can get a PCMCIA Card-to-USB converter card for your computer at a low price on either ebay or Amazon. Amazon sells used product too.
Sep 15, 2008 | Panasonic Lumix DMC-TZ1 Digital Camera
MicroSD SanDisk 2GB memory into Panasonic DMC-FZ7
Hey filmoman2008,
If you are really trying to use a micro SD card this camera actually takes normal SD memory cards not micro SD cards.
Sincerely,
Allan
Go Ahead. Use Us.
Apr 25, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
Follow this link
Feb 06, 2008 | Panasonic Lumix DMC-FX7 Digital Camera
Cameras Logo
Top Panasonic Cameras Experts
ENFORCER
deton8 von Splosion
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
