Question about Air Tools & Compressors
New Pancake, 6-gal., sand inside, what should I do to get it out of the tank? Could the sand be from the manufacturer using sand to cool the metal after manufacture?
Posted by Kim B on
Wayne Dahl
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 6 Answers
All air compressors have a water drain device on the bottom of the tank.
Get a wrench and remove this part. Shake all the sand out and maybe shoot some air up n there if you have canned air or another compressor to use.
Wrap the part with new teflon tape and reinstall it.
Posted on Jan 10, 2018
  • Kim B
    Kim B Jan 10, 2018
    Upon first impressions, I thought it was sand but I instead found that little pieces from the weld job were what was inside, about a tablespoon worth of them. Got them all out and the machine was fine after that. Didn't have to blow air up in it, thankfully. Thanks for your help.
5 Related Answers
Anonymous
  • 7 Answers
SOURCE: How much sand does it take for a BaquaPure 22 gal. tank?
if the tank is 22" you use 100 lb. 24" 150 lb 26" 200 lb.
50/50 silica sand works best.
Posted on Jun 26, 2009
Philip Shaver
  • 54 Answers
SOURCE: Portable oiless compressor wont pressurize
If there is pressure at the pump, either:
1) The tank check valve isn't opening (it's located where the line from the head enters the tank - usually extends into the tank, and the the pressure switch unloader line comes off of it as well)
2) The pressure switch unloader is bleeding off the air. This is a small valve on the side of the pressure switch. It should close when the compressor is running and open when the compressor shuts off to bleed off head pressure.
Posted on Oct 22, 2009
Testimonial: "Right on the money. The discription was very accurate. My pressure switch unloader will not close. Thanks!"
Anonymous
  • 62 Answers
SOURCE: Got a Husky 6 gal pancake, 1.5hp. motor runs- no
the regulator may be turned down, find the regulator turn it to the right to allow air into the tank, tank must have air in it to deliver air
Posted on Oct 27, 2009
Anonymous
  • 8 Answers
SOURCE: 2002 HIGHLANDER MANUFACTURER CODE
no you need an a/f sensor if the code is for a bank one it is located on the exhaust manifold on the back of the engine compartment vise versa if it is for bank 2
Posted on Nov 12, 2009
bobicehouse
Robert Moller
  • 1524 Answers
SOURCE: I've purchased Franklin Industries FBC360D outdoor Fridge...
A sealed system leak should be covered under warranty.
Posted on Apr 07, 2010
Testimonial: "Thank you but how do I contact the manufacturer...?"
I have a 6 gal 150 psi pancake compressor, once in awhile their is a leak under the cover emptying the tank . I can restart and no leak until it happens again. any idears?
Any leak under the cover after compressor shuts off is caused by the in-tank check valve. Follow the discharge airline to where it attaches to the tank. This connection is the check valve. Debris from the pump cycle (bits of piston ring) will get trapped under the valve keeping it open. Good luck
May 09, 2015 | Psi Air Tools & Compressors
How to change drive belt on my porter cable air
shouldn't have one... if you mean the timing belt inside... lol you don't wanna know
Aug 26, 2014 | Air Tools & Compressors
Can i use existing drain plug for porter-cable pancake air compressor?
Yes use pipe thread seal. The center is turned to open and close no need to remove plug. If is frozen replace.
Feb 16, 2018 | Porter Cable C2002 150 Psi 6 Gal...
My Porter Cable pancake outlet regulator doesn't seem to work.
If your quick coupler is not jammed up, (remove & test) and assuming you are pulling the regulator knob out to adjust the pressure and it is not stripped, you will need a new manifold kit.
There are about 6 versions of this unit so you will need model and type to get the correct part. There are no individual regulator parts available for this unit.
Jul 02, 2013 | Porter Cable C2002 150 Psi 6 Gal...
I have a model cw0100 1hp 4gal. and need to know capacity of oil tank.
Check you model number. I don't think cw0100 is correct. Most 1HP 4 gal pancake compressors are oil-free.
Jan 09, 2011 | Stanley FactoryReconditioned Bostitch...
I need a manual for a clarke bronco 6 gal compressor (ac20008). When I use the unit, I am cutting the circuit breaker off.
I would try a different outlet ( which should be on a different breaker ) -- sounds like your breaker is either bad or to low of a amp rating to handle the load of the compressor.
c...
Dec 31, 2010 | Clarke Power Products Inc AC2001 2HP 4...
I have a PORTER CABLE CP2600P 135 Psi 6 Gal Pancake Compressor and I have no idea how to use it. I borrowed it from a friend who is out of town and don't have instructions. I'm trying to power wash my...
An air compressor such as the one that you borrowed is very useful for airing-up tires, connecting a nailer for wood working projects and spray painting with a cup gun. All that you need do is plug it in to a 110v outlet and it will fill with air to capacity. To access the air you will need to plug an air hose into a quick coupler and adjust the air pressure with the knob showing two direction arrow. Unless your friend has included an air assisted water blasting wand that would also connect to a water supply, I do not think that it would be useful for cleaning. I have used a compressor such as this with an air nozzle or air blasting the air conditioner condenser fins and the drain to the evaporator inside the house. It will also be really great for cleaning the mower or any outdoor tool that accumulates oily dust (air filters). With a small sand blasting attachment you could remove old paint from the patio furniture or any wood or metal surface needing a good blasting to make it look like new. Sand blasting would not be practical for house/ deck/ fence because it would take too long and use too much sand; then there would be the sand cleanup. Have fun with the compressor and clean-up projects.
Sep 30, 2010 | Porter Cable Air Tools & Compressors
Oct 19, 2009 | Campbell Hausfeld No.FP2028 Gal Pancake...
Got a Husky 6 gal pancake, 1.5hp. motor runs- no air pressure ??
Air Tools & Compressors Logo
81 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
