Question about Seagate Computers & Internet
Type backup plus slim portable stdr2000103 capacity 2gb i have try to initialized the disk but it says cyclic redudancy ne 1 .... help me please... thanks
I usually figure 2 or 3 years for a hard drive life cycle. After that, I figure I'm on borrowed time. First try to check the disk for errors. Then try to delete the volume on the disc, then format - be sure to click "restore defaults".
Posted on Dec 23, 2017
SOURCE: system will not detect my Seagate ST3500641CB-RK 500gb external hard disk
My system is brand new, and completely protected with Macaffe, other USB drives are working fine, I checked Seagate External drive in other Vista and XP laptops, it is not detected in computer, as well I checked with even Device Manager, and UVCView.x86, it is not even showing as a USB device Connected.
Posted on Jun 07, 2008
SOURCE: Seagate FreeAgent External 500GB HDD - Data Recovery
well firstly if u wana recover ur data u have to make the external hdd power up but thats the major area of issue that its not powering up. the difference in plug doesnt make a difference cuz u can use the same plug,the voltage is same thorugh out in ur place from the substation. so it might be a possibility that when u connected ur hdd,the power ON/OFF switch was awredy ON IF hdd has one. so wat i feel is dat u can try opening the hdd and then connect the hdd to ur desktop with help of the BUS CABLE used to connect the HDDs in desktops. so in dat case i would suggest that u go through the manual of ur external hdd to see how to access the the casing in which the hdd is there.then if u happen to get thorugh n it turns on then u dont have to recover ur data. it would still be there. HOWEVER,its recommended that u dont try these things personaaly if u are'nt too tech savy. u shud consult a tech or a freind who knows abt this.
Posted on Oct 06, 2008
SOURCE: My laptop HP zd8000 doesn't recognize Seagate external hard drive
hi..the reason for your problem is your extenal
hard drive has been affected by viruses.The best
solution to this problem is scanning your hard drive.
once you scan it u will be free of viruses and your
laptop will be able to recognise your hard drive.
try it out..
thank u..
rate me..
Posted on Feb 10, 2009
SOURCE: Seagate Freeagent 500 GB does not detect
please format theExt HDD as soon as possible
Posted on Mar 21, 2009
SOURCE: Data Recovery from Seagate Desktop Expansion 500GB External Hard
This is a solution I have used in the past and it has worked. It's a Seagate Recover utility for end users.
https://services.seagate.com/diysoftware.aspx
If the data is absolutley critical and very valuable, you can send it to Seagate and they are very good at recovery as well. It gets a little pricey at $800, but I too have had to use that as well for mission critical data I could not afford to lose.
https://services.seagate.com/consumer_standard_services.aspx
Posted on Nov 06, 2009
https://www.susthesurfer.com/connect-the...
