Question about Mitsubishi Televison & Video
My Mitsubishi DLP WD-73873 model television only powers up when I press the Menu and Input buttons simultaneously. The tv also will power up by itself occasionally. Anyone having a similar problem?
Mitsubishi thinks the power unit needs to be replaced (non-covered) The remote still works once the unit is powered on
Posted by Kenneth Kane on
Sometime Mechanic
    Habit-Forming:
    Scholar:
  • 122 Answers
  1. Yes, this happened to my Samsung. It was the high voltage circuit on the power power. The TV has a chip that check all the circuits on all three boards. When a circuit is low, then it won't turn on. I checked 380 volts at the capacitor connected to the high voltage transformer. It should have been at 390 volts. I took out the 100 uf rated at 450 volts, but only have two capacitors lying around: 150 uf and 220 uf rated at 400 v. I connected them in parallel make them 370 uf at 400 volts, and the TV is now working fine.
Posted on Dec 21, 2017
  • Sometime Mechanic Dec 21, 2017
    1. Yes, this happened to my Samsung. It was the high voltage circuit on the power power. The TV has a chip that check all the circuits on all three boards. When a circuit is low, then it won't turn on. I checked 380 volts at the capacitor connected to the high voltage transformer. It should have been at 390 volts. I took out the 100 uf rated at 450 volts, but only have two capacitors lying around: 150 uf and 220 uf rated at 400 v. I connected them in parallel make them 370 uf at 400 volts, and the TV is now working fine. Checked the volt at the capacitors, its is 391 volts.
5 Related Answers
Anonymous
  • 4402 Answers
SOURCE: mitsubishi dlp does not get picture
the plug the connects underneath is not connecting right you have to get at the plug and seat it correctly
Posted on Dec 08, 2007
Slinteriors
Sonny Berry
  • 8617 Answers
SOURCE: television wont power on
Is the led blinking? If so please let me know how many blinks its making before pausing for a second.
Posted on Apr 13, 2008
Anonymous
SOURCE: Mitsubishi Projection TV Power Supply Board assistance - Model # WD 62525
Mr.Marxxx you need to let one of your friends fix it for a small fee.Just like everyone else does.
Posted on Jul 29, 2008
Anonymous
  • 3130 Answers
SOURCE: TV Won't Stay On...
fuse do not blow for no reason, th reason thy are blowing is he convrgence iC"s are going bad.
Posted on Aug 16, 2008
Anonymous
SOURCE: Mitsubishi WD 62327 DLP TV
Can I ask where you got the capacitor kit from?
Posted on Nov 02, 2008
TV Doesn't stay on...
HI
base in your comments in your TV you have defective power oscillation circuit! and need to diagnose your TV with a qualified technician! now if you have knowlegde in electronic trouble shooting i can give you the method to fixed your TV. Thanks in Advance!!!
Nov 15, 2007 | Mitsubishi WT-42311 42" Rear Projection...
I have a 57" mitsubishi
You probably have a bad lamp again I hate to say. These lamp are so critical when being moved. If after you atttempt to power on TV then red light shows, press menu+input on the front panel and hold for 5 seconds. Front timer LED will blink a 2 digit error code five times then stop. Code 34 and 66 are lamp errors, and if you read code 66 the lamp is broken. Good luck
Bill W
integrityhomeworx.com
Mar 09, 2011 | Mitsubishi WD-57733 57" HDTV
I have a Mitsubishi WD-62525 HDTV that suddenly wont turn on. Just has a green blinking light when you hit the power button. Any ideas?
I found this on another website, most likely it is your power supply capacitors.
  1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
  2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
  3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
  4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
  1. DM Module Capacitors have FAILED.
  2. DM Module is defective.
  3. EEPROM Board failure
  4. Power Supply failure.
Feb 28, 2011 | Mitsubishi WD-62525 62" Rear Projection...
When you turn the TV on it stops at the blue Mitsubishi screen and the power button just blinks. You have to then unplug the TV to power down. Pushing the power button on the TV or remote will not power...
There is a software update that is available for some Mitsubishi dlp models. The wd-65c9 is one of them. When I experienced your problem, I went to the website, downloaded the update, and installed it on my tv and boom, its fixed. It's super easy, free, and takes a few minutes.
Jan 31, 2011 | Mitsubishi WD-65C9 65" DLP HDTV
Mitsubishi WD-65731 DLP HDTV , status indicator constant red when tv is turned on and nothing happens. Error is 5 pause 9 repeat, after pressing menu and input buttons
Chassis V33. Says DM board short detected (error 59). Could be power short on DM, or communication line short. Should get diagnosed by repair shop or MITS service.
Apr 13, 2010 | Televison & Video
Have a Mitsubishi WD-62327 DLP projection TV. It is a few years old. Would not turn on. Blinks red - 3 short red blinks then 1 longer blinks - and repeats. We have disconnected everything, unplugged,...
if you hold the input and menu button for 5 seconds it will flash you a code 36 is the lamp fan / dmd fan has gone bad. pretty common. not hard to change but will cost 100 in parts and whatever labor may be
Jan 18, 2010 | Mitsubishi WD-62327 62" Rear Projection...
Green blinking light
needs to be reinitialized press menu 8970 to reset
Oct 15, 2009 | Mitsubishi WD-52525 52" Rear Projection...
My 2 1/2 yr old Mitsubishi 65 inch DLP will not turn on.E code 12
let it start up you will here things happening, engine will start first then a buzz to start the lamp if you here all of this you have a bad lamp.You should have a error code let the tv try to start leave it alone and see if you have an error. As soon as you reset the tv you loose the error.
May 01, 2009 | Mitsubishi WD-65732 65" Projection HDTV
Aug 17, 2008 | Mitsubishi WD-62327 62" Rear Projection...
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
Paul Bade
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
