Question about Manitowoc Kitchen Appliances - Others
SOURCE: water is flowing over cold
Possible clog in float valve or solenoid is stuck open
Posted on Feb 02, 2009
SOURCE: Food and water freezes but ice cream is soft
Check the door gasket seal.
Open the door for a few seconds and then close.
Immediately open the door again, and, if sealing properly, it should take more pulling force to open the door.
Posted on Mar 30, 2009
SOURCE: Ice Maker frost and freeze where ice drops into refrigerator door
You need a service guy to look at it. It could be water leaking or a simple case that the flap isnt sealing and the ice melts and then freezes the flap open
Posted on Aug 23, 2009
SOURCE: i have a manitowoc commercial
Check to see if the compressor is running... if it is running and not cooling then it may have a refrigerant leak...
If the plate is getting cold but the water is not freezing then check to make sure that the float is not stuck on and the the water just keeps running in... that will keep the water warm enough so that it does not freeze...
heatman101
Posted on Mar 10, 2011
Sep 17, 2014 | Manitowoc QY-0214A Self Contained Ice...
Mar 04, 2014 | Manitowoc SY0454A S Series Ice Maker...
Sep 16, 2013 | Manitowoc SY0454A S Series Ice Maker...
Sep 11, 2013 | Manitowoc SY0454A S Series Ice Maker...
Feb 12, 2013 | Manitowoc SY0454A S Series Ice Maker...
Nov 25, 2010 | Manitowoc Heating & Cooling
Nov 17, 2010 | Manitowoc SY0454A S Series Ice Maker...
Nov 11, 2010 | Manitowoc SY0454A S Series Ice Maker...
74 people viewed this question
