SOURCE: satellite dish receiver error LNB Drift detected
that's not true i work for dish network if u have an LNB drift of -8 or +8 you can get a free lnb service call and they can come out n fix at no charge
SOURCE: decoder keep scanning
well, firstly. u have a sat finder!! great!! now lets see if i can teach u how to use it, when you hook it up there will always be some sort of signal, (other electronic waves in the air) the best way to check is to put ur hand in front of the LNB (the square box in front of the dish) if he signal goes down, the signal was fine to begin with, if it goes up, the dish is out, if nothing happens... dead LNB, which in my experiance, the most likely cause, dont for get to reset your decoder once you have solved the problem.. good luck
SOURCE: Changed from single to twin LNB, no signal
HELLO
Here is a suggestion! Try SKEWING the LNB around a few degrees. Looking at the front of the dish, turn your LNB to the LEFT slightly (that is anti-clockwise).
Sometimes it's the little things that matter most where installation is concerned. It is also possible that due to the weight of the new LNB, the alignment may be out.
The angle and azimuth depend on the position of the satellite. Contact any technician. Gopakumar Gopalan Google
It is not easy to predict the exact angle and azimuth. You should have a signal meter to proceed.
SOURCE: lightning run through coaxial cable
Amazon com Charm sonic 2Pack 4 9Feet 1 5Meters Lightning Cable USB Charger...
