What do these Transformers go to?
I have these and have no idea what they go to...please can you help? 1. Ktec KA12D120030033U 2. HON-KWANG D12-10-1000 part no: SAM01T
Posted by Kayci Jones on
Samuel O'Donoghue
    Dedicated:
    Visited the website for 20 consecutive days.
  • 337 Answers
Try google (1. Ktec KA12D120030033U 2. HON-KWANG D12-10-1000 part no: SAM01T) maybe one at a time
What do these Transformers go to? - 6016215f-e054-4f2b-9d13-42b0e491d44b.png
Posted on Dec 21, 2017
Testimonial: "I did a couple times and only found how much to replace. not really info on what they go to..."
  • Samuel O'Donoghue Dec 23, 2017
    These power blocks will work for any number or types of equipments. Looking at a particular device there will be markings similar to the power pin illustration on the power block. The mechanical aspects of the output plug receptacle must match the input receptacle on the equipment and the voltage /milliamp rating of the block should equal or exceed the equipments need/demand also marked on the equipment IE.in the posted image you will see that the power block has a rated output of +12 volts and 2 amps (+12v 2A). If the equipment needs, in amps or milliamp are less than the blocks rated output and the voltages are the same as listed on both block and equipment and the plug to receptacle relationship is compatible you may use that block with that equipment
2 Related Answers
Borhan
  • 109 Answers
SOURCE: Sound Won't work. Realtek AC97 won't install.
Remove previous installation completely and install it again. Thanks
Posted on Oct 17, 2009
SOURCE: Mixed up my power supply for my dvd1170e external drive what is the correct input andoutput for this device?
You need one with the following attributes:
Output Voltage: 12 Volts DC
Amperage: 1.8~2 Amps
You can buy a replacement at http://www.lcdpayless.com/productpage.php?productId=8562
Posted on Nov 25, 2012
Nov 30, 2011 | HP dvd1170e DVD-RAM Burner
I need to know the amperage for the power source for the tiny tailor. The power source is missing and i need to replace it.
I have the original power source - it is Hon-Kwang, class 2 transformer D45-10
Input 120V 60 Hz 12w
Output 4.5Vdc 800mA
Hope that helps - that is all it says
Dec 16, 2010 | Singer Tiny Tailor TT700
Where do I get an AC power cord replacement for a Drscholl X-pression full cushion Massager?
You might want to check ebay with item number 150448130561. But check your adapter again if it looks the same. As per manufacturer's information the power adapter is a Hon Kwang Adaptor with Model number - A 12- 1A. As long as input and output capacity is the same, this should work.
Oct 27, 2010 | Computers & Internet
My env 2 shuts off after about 1 minute. battery
well hon its beacause u need a least 1 hour or 30 mins. for it to charge
Dec 01, 2009 | LG Cell Phones
Oct 16, 2009 | Computers & Internet
Shark cordless 15,6v need to buy ac adapter Ktec KA12D220020034U
need a Ktec ac adapter listed above. KA12D220020034U. HOW MUCH FOR THE ADAPTOR AND HOW SOON CAN I GET IT.
Aug 30, 2009 | Vacuums
I need to replace an AC transformer for harman kardon PC speakers
If you still need it, I have the Hon-Kwang Plug in Class 2 Transformer Model A15-110.
Apr 05, 2009 | Harman Kardon HK206 Computer Speakers
HK206 speaker power supply
this is power adapter specs for HK206 found elsewhere
Made by: HON-KWANG
Plug in class 2 transformer
Model No: D12-10-1000
P/N: 66-000-118-01
INPUT: 120V 60Hz 25W
OUTPUT: 12VDC 1000mA
The polarity is negative (-) on the outside and positive (+) on the inside.
I will try RadioShack for this...
Aug 24, 2008 | Harman Kardon HK206 Computer Speakers
Computers & Internet Logo
109 people viewed this question
Ekse
Marvin
Marvin
