I've never worked on your brand name stove but i want to tell you don't self clean it until after the holidays,when you self clean an oven it gets up to 1000 degrees,the heat can damage the electronics in the oven,if it does and you need a part ordered you won't have an oven to cook with for the holidays,after what i've seen i will never self clean my oven again with the self clean feature i use easy off just as good.hope this helps you out and merry christmas
SOURCE: pyrolytic cleaning fault
fixed very simply just turned off oven at mains turned back on and it worked perfectly!!!!!!!!
SOURCE: Receiving F3 Code
HI, no need to replace the unit at this time. this is a Open or shorted oven temperature sensor (RTD).
Check sensor harness and harness connection between oven sensor and oven control.
Replace oven temperature sensor (RTD) if wiring is ok.
SOURCE: Neff B4562 Pyrolytic Cleaning Not Working
You need to remove the rack side supports too. Its not clear in the book as it just says shelves and racks but everything needs to come out the oven.
SOURCE: MIELE H 4641 PYROLYTIC OVEN
I HAVE THE SAME PROBLEM. KEEP HAVING TO TURN IT ON AND OFF TO USE IT.
SOURCE: Pyrolytic cleaning won't start. Neff B15P42.0 GB
you have to remove the shelf supports (left and right) as well as the shelves. The manual tells you about the shelves but not the supports. I only found out as someone wrote the answer on another website
