Batteries never last but you can get replacements. Try this website. Dyson
SOURCE: Hoover Alyx 2000w, no power. Help!??
Its a possibility then that if the fuse has been replaced that the cable inside has either come apart or you have a broken switch. If its only a year then you should be covered automatically with Hoover's guarantee.
SOURCE: Hi, this is our third Dyson DC-16.. the Trigger
How are you charging your battery? Every battery has a memory. If you dont let it die the first come times then charge to full the battery will assume 40% is 100%.
Testimonial: "Thank you for your solution, but we've had it at least a year.. it stays on charge when not in use.cleaned the connections.working better, not 100%.."
SOURCE: Its spark at the back of the motor when its turn on.
yep very common of dyson vacs you will have to get the motor replaced not an easy job to do you might if you dowant to give it a go go on to youtube n search for fit dyson motor that will show how its done good luck
SOURCE: Have a Dyson DC16 -
After two years the batteries are probably no longer holding a charge and need to be replaced.
SOURCE: dyson dc16 battery not hold full charge, all three
If you're concerned that your DC16's battery doesn't seem to be working correctly, please get in touch with us directly. One of our experts will be happy to run some troubleshooting over the phone with you to determine whether the battery needs replacement.
You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
