SOURCE: ac relay location 2004 pontiac vibe
look in the fuse panel located in the engine compartment near the battery
Robert
Please take a moment to rate this solution.. thanks
SOURCE: where is the cabin air filter in a 2005 pontiac vibe?
Hi Ncrver,
The Cabin Air Filter is located inside of the glove compartment.
Best of luck,
Lazaruselite
SOURCE: tranmission solenoid 2005 pontiac vibe
we had the computer code p2716 on our 2005 pontiac vibe -shift solenoid. gm says to replace the pcm before you do anything else. we tried this and it works.
SOURCE: 2005 Pontiac Vibe suddenly won't start.
nutral safty switch try moving the shifter from P ... to N....P....N....P.....N
SOURCE: 2005 Pontiac Vibe heater fan working on high only
My 2005 Vibe did the same thing it was the heater resistor. It is located to on the firewall behind the glove box on the lower left side of the blower assembly. Two 5.5mm screws hold it in place (1/4 inch socket works too). I used a socket attached to a socket swivel to replace mine in under 10 minutes. Heater now works as good as new. I purchase mine online for $30 from rockauto.
