Question about Maytag Refrigerators
Will Whirhpool ice maker 4317943 work in a maytag MFD2562kes?
Posted by Alexander Soon on
Melissa Martin
    Master:
  • Maytag Master
  • 753 Answers
Yes
Posted on Jan 01, 2018
5 Related Answers
Michael Anderson
  • 172 Answers
SOURCE: I have a Whirlpool side
Humm thats a good one, but I will try to help you out. First off you say the icemaker is new, so does that mean you bought the icemaker and installed it on the refrigerator. Or is the refrigerator new and it has an icemaker. If you installed the icemaker new on an older refrigerator you can have a few problems. Most likely the freezer is not getting cold enough for the icemaker to cycle on its own. Especially if you are peaking in every few minutes like I would be doing. The icemaker will start a new cycle when the temperatur hits 0 degrees. If the freezer is only getting to 5 degrees the icemaker will not cycle. In that case the problem would be with the refrigerator not the icemaker. If the freezer is getting to 0 degrees then you may want to take that icemaker back and get a replacement. Good luck and I hope I helped. [email protected]
Posted on May 02, 2008
David Coomer
  • 1073 Answers
SOURCE: Ice Maker Won't Drop Ice
you have a problem in the module of the ice maker if it is new take it back for a new one
Anonymous
SOURCE: Maytag MSD 2432GR Water not feeding into Ice Maker
one possible solution is that the ice maker water valve has failed (solenoid). I would try switching the wires on the water valves and see if water goes into the ice maker when you push the water dispenser button, if it does the valve is ok. If you go this far go ahead and fill the ice maker with water ( about half to two thirds full) switch wiring back as first found and see if maker will freeze and dump ice, if it does ok, if not the problem is probably in the ice maker.
Posted on Sep 08, 2008
Henry Russ
  • 31 Answers
SOURCE: maytag ice2o won't make ice
theharrisont,  You state that...." ice maker stopped working after it flooded our kitchen floor."  The water works because the water fountain dispenser uses a separate part of the Water Valve. The ice maker portion of the water valve is defected and the entire Water Valve Assembly will have to be replaced.  Your problem is the dual Water Valve Assembly which is located on the rear bottom area of the refrigerator (follow the water inlet line from the wall to the refrigerator...the water inlet line connects to the Water Valve Assembly).  The significant info which you provided was that the ice maker flooded the kitchen which indicates the Water Valve Assembly is defected. Failure to replace the Water Valve Assembly will result in the same problem of flooding at some later date.  Replacing the dual Water Valve Assembly is just one step of several steps necessary to correct the problem.  You will also have to temporarily remove the ice maker from the freezer (usually a couple of screws hold it to the wall and a quick disconnect electrical plug) and put it in the sink and run warm water over to remove any ice.  Before you reinstall the ice maker you must check the Water Fill Tube that dumps the water into the ice maker.  Because you said that the ice maker flooded the kitchen, then the Water Fill Tube is probably filled solid with ice which must be removed.  A hair dryer is a quick way to achieve this.  Blow hot air directly into the end of the Water Fill Tube which dumps the water into the ice maker.  Note:  Use a long screw driver to insert into the Water Fill Tube to break loose any ice and continue to use the hair dryer to help to remove any ice. This should correct your problem
If you need further help, I’m available over the phone at https://www.6ya.com/expert/henry_239f63a136de60f0
Posted on Feb 07, 2009
Anonymous
SOURCE: Maytag plus MSD2756GEQ ice maker not working
I had similar problem in that the fan in the freezer that blows freezing air into freezer and over to fridge was not working. Fridge was running warm (over 40 deg and freezer up near 20) Service call around $160 with new fan.
Posted on Apr 12, 2009
Ice making parts need to be rescrewed into mechanism
Refrigerator Repair - Replacing the Ice Maker Shut-Off Arm ...
? 8:09
https://www.youtube.com/watch?v=nTG9R4arsQE
Mar 19, 2013 - Uploaded by PartSelect
SourceCode=15 Click here for more information on this part, installation in... ... Refrigerator Repair ...
Replacing the Icemaker (Whirlpool Part# 4317943) - YouTube
? 5:51
https://www.youtube.com/watch?v=ECdu8xqf0Ns
Apr 5, 2011 - Uploaded by PartSelect
Refrigerator Repair- Replacing the Icemaker (Whirlpool Part# 4317943) ..... snap the circuit board cover onto ...
How to Install a Refrigerator Ice Maker Kit - YouTube
? 2:49
https://www.youtube.com/watch?v=zR3Jt7k39Zs
Jun 26, 2015 - Uploaded by searspartsdirect
Leave the mounting screw loose. Install the mounting screws into the side freezer wall leaving enough ...
Jan 01, 2016 | LG Refrigerators
My Maytag M1TXEMMWWB00 (209 cu ft) Top Freezer Refrigerator will not make ice. I checked the solenoid where the water comes in to see if it has a current and it doesn't (no juice). I looked at the owners...
The ice maker tells the water valve to open so you will not see the power until the ice maker ask for water. Does the ice maker have ice remaining in the ice slots? If not then fill with tap water and after the water freezes and ice maker cycles dropping the ice into the ice bin if it does not refill with water then you will only need to change the=> 2315576 Water Inlet Valve If the ice maker does nothing you will need to change the ice maker=> 4317943 Ice Maker Assembly You can find trouble shooting info at Appliance 911
, Thanks John Tripp
Feb 19, 2014 | Maytag M1TXEMMWW (209 cu ft) Top Freezer...
No power between L & N on maytag ice maker module
Yes there is. http://www.partselect.com/358591-1-M-Whirlpool-4317943-Replacement-Ice-Maker.jpg
If you look at the black line of the wiring harness you'll see a white block looking thing, but if your trying to jump the ice maker go between n and m, that way you can actually see if the whee moves or not letting you know that power is there.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 05, 2012 | Maytag Refrigerators
WHAT MODEL ICE MAKER DO I NEED FOR A ET18PK FRIDGE?
the part # is 4317943
it is i/m kit that comes with several different wires to match the plug equipped on your ref.
it fits all whirlpool brands including but not limited to; Whirlpool, Maytag, Kitchen Aid, Kenmore,Amana Estate,Roper and many more brands manufactured by the Whirlpool Corp.
at Sears it cost over $120.00 and at the link i have included it cost $70.00(plus shipping)http://www.filtersfast.com/Whirlpool-4317943-Icemaker.asp
copy and paste it if necessary
Jul 22, 2011 | Whirlpool Refrigerators
Hello. I have a Kenmore Elite side by side refrigerator, model# 106.50502990. It was manufactured in March of 2000. The ice make broke and I need a replacement. The ice maker part# I got is 4317943. ...
4317943,i looked it up it says that this is the ice maker for your machine,do you know that it comes with different harnesses,or take off the old harness and put it on the new ice maker,it does have 4 wires on each harness,i just called sears for you and the guy i talked with says that's the ice maker for your machine and there's no substitutes for it,that should be your ice maker
Oct 19, 2010 | Kenmore Refrigerators
Ice maker won't work
Your inlet tube that goes to the icemaker may be frozen. To Check: Shut off water supply to Fridge, disconnect the water line that goes to the icemaker at top back. Use a flexible item to insert in the water line connection. I used a zip tie. If the flexible item won't all the through to the ice maker, the line is frozen. Thaw out the tube from inside the freezer with a hair dryer. Re-connect everything, you now have ice . . . Solution #2: You may have to replace your "Water Inlet Valve" located at bottom right rear of Fridge. Easy to do, just follow the color codes, be sure and shut off the water.
Jun 06, 2010 | Maytag MFD2562KES Stainless Steel Side by...
The ice maker just stopped making ice.
First , pour about 2/3 cup of water into the ice maker . If if freezes , and dumps , replace the water valve ( pt. # 4389177 ) . If it does not dump the cubes , replace the ice maker ( pt. # 4317943 ) . After pouring the water into the ice maker , remove the bottom kick panel , and clean the bottom coils , of dust , lint , pet hair , etc , as this will raise the freezer temp . An ice maker has to be 5 degrees , to operate , correctly . If ice maker starts working , after cleaning the coils , GREAT ! ( it does happen ) .
Dec 04, 2009 | Whirlpool ED2FHEXN Side by Side...
May 02, 2008 | Refrigerators
Refrigerators Logo
41 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
