Question about Kenmore Refrigerators
I have a Sears Kenmore Elite Bottom Freezer it's been working fine but tonight I go to get water out the door and ER IF came up on the panel...May I ask what is the error?
Posted by Trist Perroncel on
Donald Wilson
    Habit-Forming:
    Filmmaker:
    Uploaded 5 video answers.
  • 31 Answers
I think your error code is actually ER 1F not ER IF.
Here is a youtube video that should help.
Posted on Dec 19, 2017
5 Related Answers
Anonymous
  • 8 Answers
SOURCE: Kenmore Elite Trio electronic panel displays 'Er IF' and touch buttons not working
I have the same problem!
Posted on Nov 04, 2008
Dave Harrison
  • 114 Answers
SOURCE: Kenmore Elite Trio Error Message ER DH
This is a refrigerator manufactured by LG and is well known for this type of malfunction. There should be two 1/4 inch screws on the outside of the freezer drawer tracks near the front that will allow you to pull out the entire door assembly. Once this is done and the unit is fully defrosted and unplugged, there are a couple/few screws in the back freezer panel. Once the panel is removed, this part is located on the upper right side of the evaperator coils. It is sometimes wedged in tigtly but should pull out with a good tug. Unplug the white harness, remove defective part and reverse this process. Good luck and happy shopping for the shoes.
Posted on Aug 25, 2009
Testimonial: "Thank you! Your assistance helped me a bunch and fixed my problem"
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Elite Refrigerator Trio display panel read
This is an error code for the icemaker fan motor.
If the control does not see a signal coming back from the fan motor you will get this error code.
Please see the image below from the service manual that explains the ER IF error code.
http://media.fotki.com/1_p,wkbwtkdqbqkgrkkxgtqsskgwtqkq,vi/ktfgsrbbdxktrrwffdr/1/1303472/5961857/image18067img-or.jpg
The ER IF code indicates a failure of the icing fan.
You may notice slower ice production but the other fans should be okay.
You can select the ultra ice option and see if the fan toggles on.
The fan or the control is bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 23, 2010
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: Problems for Refrig. Kenmore Elite
The Er DH error code indicates the temperature sensor on the evaporator coil did not reach 50 degrees within one hour.
This would indicate the control board did put the refrigerator through a defrost cycle.
This problem could be caused by a defective relay on the control board, a defective defrost heater, a broken wire to the heater, or a stopped up drain on the defrost pan causing ice to form on the evaporator coil.
Before replacing the control board, someone should remove the food from the freezer, remove the freezer drawer, and remove the evaporator cover to expose the evaporator coil, heater, and defrost sensor.
The voltage to the defrost heater should be 120 volts ac.
The defrost heater is part of the evaporator coil and is not replaceable as a separate part.
You can test the operation of the defrost system by pressing "Ultra Ice" and "colder freezer temp" for 3 seconds.
The first time you press and hold the buttons the board will test the compressor, fan, and open the damper.
All displays should be on.
The second time you press and hold the buttons the board will test the compressor, fan, and close the damper.
The third time you press and hold the buttons, the board will turn the compressor and fan off and turn the defrost heater on for around 25 minutes. This would let you know if the defrost system is working.
http://knol.google.com/k/fixing-the-er-dh-code-on-kenmore-elite-trio#
Posted on Sep 25, 2010
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: Temp control is displaying Er and FF code
This is an error code that pertains to the evaporator motor but could also be the main board.
If the evaporator motor is running, the main board will probably need to be replaced.
It could be a wiring problem but it's not very likely.
If the motor is not running, some voltage checks will need to be made, at the motor and board, to determine which component has failed.
These checks require a meter and can be difficult to make, even for a technician.
What does Kenmore refrigerator error code er co mean?
I just did a google search. It seems that it is a communications error between the computer in the back of the refrigerator and the front panel display,. Some people have replaced the computer only to find that the problem stays. At least two have found that wires have broken in the front door.
The wires get flexed when the door is opened and closed.
Use your model number at the sears parts direct to see user manuals diagrams and parts lists. Link below.
http://www.searspartsdirect.com/
Sep 06, 2014 | Kenmore Elite 29 cu. ft. Grab-N-Go French...
I CHANGED THE FILTER AND SET THE SETTINGS AND IT BEGAN TO WORK A FEW HOURS LATER THE DISPLAY WAS SHOWING ER NOW THE REFRIG. IS NOT COLD AND THE FREEZER IS NOT WORKING AND THE ICEMAKER IS NOT WORKING ALL IN...
If this is the Kenmore french door model with bottom freezer and ice and water in the door made by LG it could be that the mother board has failed.  Call for service and hope that warranty is still in effect.
May 19, 2009 | Refrigerators
Kenmore Elite SS Bottom draw freezer refrigator is a lemon
Hi!!! you have to change your freezer fan and bi-metal which are upgraded good luck..call manufacture and see if you have a service flash and covered under warranty..good luckk...
Jan 19, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite model 73503201, Refrig hot, freezer working.
first, sears doesnt make any of their own appliances, but they do sell them, so you can be upset, but it is fixable. what is happening is the freezer fan is not running causing no cold air to circulate. the reason the door strip feels hot is it has a heater to prevent condensation and when the unit is cooling properly it will feel normal temps.
check to see if you can hear the fan running in the freezer, if it is then you may have a defrost problem, but most likely you have a bad fan motor. remove the rear panel in the freezer and check the fan to see if it is turning. if not replace the motor.
Dec 26, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Control Pad displays Er CO.
The Er Co error code signifies a communication error between the display control board on the freezer door and the main power board on the outer back panel of the refrigerator.
Check the wiring and connections between the low voltage interface and the main high voltage board.
If you are able to unplug the refrigerator and remove the cover over the control board on the back of the refrigerator,
you can check the wiring connection on the main control board.
If this wiring connection is okay, check the wire harness connection under the hinge cover on the top of the left hand refrigerator door.
If these connections are okay, then you will need access the wire harness connection in the dispenser.
Nov 30, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore ELITE error code ER FF
ER FF error is malfunctioning evaporater fan
hope this helps
Oct 18, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore Elite 795 75542401
I replaced my "entire" ice cube maker (tube,hoses,water pump, ice maker) and it still pooled water at the bottom. I removed the back panel in the freezer and noticed the ciols go through a defrost cycle and water forms in tray under coils. I removed the lower panel on rear of fridge -and found a drain hose near the water solenoid/pump. I blew compressed air into the hose and hopefully unblocked it so it can drain into the pan not the freezer.
Jul 16, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore 795.7731 Fridge warm;freezer cold - Error er dH
I faced the same problem for Kenmore elite Trio Model # 795.77543600 bottom freezer refrigerator. The issue as pointed out by Medeer on fixya.com, turned out to be the part called component assembly, part number 6615JB2005H. I got this replaced yesterday but for 4 hours I did not notice any cooling... so I thought it did not work.... but then in the morning I notice that the issue has been resolved, the refrigerator is cold and there is no eR dH error message. Thanks to all who shared on this site.
Feb 07, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
144 people viewed this question
Top Kenmore Refrigerators Experts
Jimmy
John Tripp
John Tripp
Dale Copeland
Dale Copeland
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
