Question about Power Computers & Internet
I have a fl8...its getting power but nothing lights on screen
Posted by Felix Makarewicz on
  • Anthony Cardenas
    Anthony Cardenas Jan 07, 2018
    Hi Felix Makarewicz, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    NO CLUE what you are writing about!??
    "fl8" ain't gonna cut it.
Toshiba 55 55S41U Black screen no back light no picture green power light
have you checked for dry joints or blown capacitors , with a power surge depending what kind voltage or amperage the circuit received it might have even blown screen connect it will certainly fry a lot of components ,have you looked for holes in capacitors ,resistors or burnt tracks between components . that's about all I can think of to check also some power panels have built in fuses to stop surges if you could obtain a circuit diagram that should help you also you could google your query and see if you get any assistance it costs nothing and you could get your TV up and running again . All the best .
Dec 19, 2015 | Toshiba Televison & Video
Blank screen
  • With the computer on, use a flash light to inspect the screen. If you can see a very faint image then either the inverter board is bad or back light. Usually its the inverter.
  • If you get nothing, plug an external monitor and toggle the display to it. If you get output then your screen is bad or possibly a loose video cable.
  • If you get nothing, power off, pull battery pull all memory out. Power on computer. If you get BIOS and a no memory error, one of your memory modules is bad.
  • Still nothing, then the motherboard is bad.
Jan 29, 2013 | Acer Veriton Z290G 185 320GB
I have an HP DV9000 that I'm having an issue with on power up. When I plug the AC adapter into the laptop I have the blue light on insert so I know the laptop is getting power. When I depress the power on...
Unplug your battery and leave it off for about 10 minutes. depress the power button(with the battery off) to get rid of excess power. reconnect the battery and try again. If no luck, try with power cable only(no battery) if no luck, sounds like a motherboard issue.
Oct 29, 2009 | HP Pavilion dv9000z Notebook
Unable to solve Blank screen
hmm confusing but try turning your ps3 off at the wall give it 5mins and try again if nothing happens try it on another tv
Sep 25, 2009 | Sony PlayStation® 3 (80GB) Console
Blank Screen
HI there.
Try booting into safe mode by pressing F8 while the computer starts up.
If you can get it into safe mode perform a system restore.
If it won't boot into safe mode please post back.
Good luck and thanks for choosing FixYa!!
Jun 02, 2009 | Acer TravelMate 4230 Notebook
Vizio P50HDM No Picture/No Sound
this is most likely the sustainer board(s) problem. Replacing the sustainer boards should correct this problem for you. you can get the parts at vancebaldwin.com
May 29, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Power light comes on but nothing shows on screen
send to the following people they will get it working again for u http://www.psp-repairz.co.uk/
Feb 19, 2009 | Sony PlayStation Portable (PSP) Console
Black screen
how can u fix this black screen? the green power light is on, shows vista for a bit then turns black and stays black. any solutions or do i have to send it back?
Apr 03, 2008 | Microsoft HannsG HU171D 17" LCD Monitor
Computers & Internet Logo
23 people viewed this question
Top Power Computers & Internet Experts
EKASYS IT SERVICES
EKASYS IT SERVICES
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Power Computer and Internet Expert? Answer questions, earn points and help others
