My indiset washing machine is not working, every time I try to switch it on at the wall, it blows the db board. How,do I open the stuck door to get my washing out ?? No,water in, door jammed
Posted by Bridget Weir on
Dw Wooten
    Sergeant:
  • 227 Answers
U should beable to turn power off to washer for 5min an door should unlock if not you may need to call a appliance repair service ok
Posted on Dec 18, 2017
5 Related Answers
Anonymous
SOURCE: Door Wont Open
Your washing machine is fucked, and your clothes probably have more chance of fitting your cat than they do you. is your washing machine french...?
Posted on Jan 02, 2008
Anonymous
  • 32 Answers
SOURCE: WF860 Door stuck in closed position.
FIRST switch off and unplug.
Pull machine out and remove lid by undoing self tapping screws at the top back. May have to slide lid back a bit to lift off.
Internal catch mechanism will be reachable from top for manual release. You may need someone to push door inwards while you release catch.
Good luck
Posted on Apr 13, 2008
Anonymous
  • 196 Answers
SOURCE: Washing Machine starts, squirts water, then stops.
E5E  IS FOR  Communication problem. THERE IS 100 %WIRE SHORTING SOMEWHERE.PLEASE CHECK OUT.
ALSO OTHER ERRORS Error code - Fault condition
E11 Fill time too long.
E13 Water leak in tub or air leak in air bell.
E14 Reed switch.
E21 Water not pumping out fast enough.
E23 Drain pump relay on control board failed.
E24 Drain pump relay on control board failed.
E31 Better models. Pressure sensor not communicating with control board.
E35 Better models. Pressure sensor indicates water overfill.
E41 Control board thinks the door switch is open.
E42 Door remains locked after cycle is completed.
E43 Control board problem.
E44 Control board problem.
E45 Control board problem.
E46 Control board problem.
E47 Board thinks the door PTC circuit is open in spin.
E48 Board thinks the door PTC circuit is closed.
E52 Bad signal from tacho generator.
E55 Motor overheating.
E56 High motor current.
E57 High current on inverter.
E58 High current on motor phase.
E59 No tacho signal for 3 seconds.
E5A High temperature on heat sink.
E5B High temperature on heat sink.
E5C High temperature on heat sink.
E5D Communication problem.
E5E Communication problem.
E5F Communication problem.
E67 Input voltage on microprocessor incorrect.
E75 Better models only. Water temperature sensor circuit.
E76 Better model only. NTC temperature for the cold water valve over the limits.
E95 Communication error.
EB1 Incoming power frequency out of limits.
EB2 Incoming line voltage above 130 VAC.
EB3 Incoming line voltage below 90 VAC.
EF1 Clogged drain pump.
EF2 To much soap.
Posted on Nov 12, 2008
Anonymous
SOURCE: Maytag Neptune washer front load- Can't open the door
Take out the bleach and softener tray (it just lifts out, angle it a little) and unscrew the 4 bezel screws and take out the bezel. You will find a red or green plastic pull line that is supposed to release the door. You may have to "man-handle" the door a bit and pull hard on the line before it will release. Once you work on the door release mechanism (I had to replace the wax motor again, even though it was the "upgrade" black plunger type) I recommend shooting a little silicon spray on the white plastic moving parts of the locking mechanism to get them to move more easily.
This is true on a Maytag Neptune MAH3000AWW front loading washer. Mine is 11 years old, and had the initial wax motor work done at 7 years.
Posted on Jul 07, 2009
Anonymous
  • 24 Answers
SOURCE: Washing Machine Door is jammed (Indesit WD12x): I
UNPLUG IT
Posted on Oct 13, 2009
Error code E07 on my Hoover WDYN 854 DB results in me not being able to open door after a wash cycle any ideas how to open door
Switch off and for Door lock fault or Motor fault .
Check both are ok and make sure nothing is jammed or restricting the operation as it is according to which main board is fitted to the machine.
Feb 02, 2015 | Hoover Washing Machines
HOTPOINT WASHING MACHINE wmf540
You will have to find the component in the machine that has
gone live to neutral,live to eath or neutral to earth if it is protected by a RCCBO. Check on the back of the printed circuit board for "BLOWS" black marks blown components.
Jan 10, 2014 | Indesit Genuine Hotpoint Wmf540 Wml520...
Door willnot unlock after wash is complete
switch is stuck. need to take the top off. and move the door lock to the side and open the door at same time make sure it is up plugged and has no power wile ding this. sometimes it can be easier and just turn the power off at the wall and wait 10min and it will be able to open. but if the switch has failed as they can do you need to do it the way at top of this. when open don't use until the door switch is fix as it will keep doing this on every wash.
Oct 06, 2013 | Asko W6021 Front Load Washer
My servis m6011 5kg washing machine door won't
Possible that the door lock has jammed and so is not working.please check this link: door lock
Jul 03, 2012 | Washing Machines
I have a Samsung Eco-bubble 8kg washing machine. And the problem withthis machine is that after completing washing, the door is not unlocked. I have tried to make another washing operation so that maybe it...
Mine does this when the filter is blocked. (SE) on the light indicator. Switch it off at the wall for 5 mins. Turn back on at the wall and after 20-30secs you will hear a click. Open the door. When you turn the machine on with the on/off switch, the door will lock again. Run through a quick wash. Hope this helps someone :)
Aug 21, 2011 | Washing Machines
My machine has a small water leak though the door during washing
Replace the gasket. Or make sure that the gasket is sealed properly
Feb 10, 2009 | LG WM-2032H Front Load Washer
Indesit wia111 stuck on spin cycle
OK - Try this:-
1. Position the dial on number 0 (off) and then unplug from the wall.
2. After at least 24 hours plug back in - hopefully the thing should have reset.
3. This is really important. Select a wool wash program (No 9) and allow it to complete the entire wash until the door lock light starts flashing to say it's finished.
4. Turn the dial back round to position 0 and all LEDs should go out.
That's it - The control board is reset and all should be well
In order to prevent re-occurance, try to avoid canceling programs mid-cycle. It's also a good idea to switch the dial to number 0 and switch the machine off at the wall when not in use if at all possible.
Please let me know if this works for you :)
Jul 30, 2008 | Washing Machines
Door lock light flashing
WASHDOCTOR
Rank:guru_s.gif Guru
Rating: 87%, 146 votes
IF you machine is a wma39 not a wmm39a then what has happed is that you control board is blown basically.
TO check this remove the soap draw and you will c three screws remove them... TO make removing the panel easier i would suggest removing the top as well as the front panel is wedged into it.. Then unclip the board from the panel and you will c where the big wiring plug is attached that the tracks on the board are blown.. There is no point replacing the board untill you can work out what has caused it to blow because it will blow again.. Its usually the motor or the doorlock which blows the board.. Trust me i been dealing with this type of machine for years...
Apr 29, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Follow up to asko w6021
try replacing the pressure switch i have had this fault before.the rear sensor supplies the correct water level,the front switch controls the heating and spin cycle.keep me posted.Iwork for asko i will speak to tech support on monday and let you know thanks.
Mar 29, 2008 | Asko W6021 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
