Lands Phones Logo
Jay Denham Posted on Dec 18, 2017
I have a Uniden model D1780. I have 8 handsets.I have registered 6 including base headset. I try to register either one of the 2 remaining headsets say Registering then it say Registration Failed.
Robert Orndorff
Level 1:
  • Contributor 1 Answer
  • Posted on Mar 08, 2021
Robert Orndorff
Contributor
Level 1:
Answers
Questions
0
Helped
325
Points
I had this exact problem on a D1780 and solved it by un-registering all of the handsets and then re-registering them. Before I did that it would only allow six phones to be registered at a time.
3 Related Answers
Anonymous
  • 3 Answers
  • Posted on Feb 14, 2008
SOURCE: Handset not registering with base
You could try to clear all the memory from the base unit and start again!!!
Instructions to clear phone (Uniden 8855).
1. Go to your base unit.
2. Put your flip phone in the cradle.
3. Press down and hold down (AT ALL TIMES) the end (find hs) button.
4. Whilst holding down this button, take the power plug out of the wall.
5. Whilst still holding down the end (find hs) button, plug the power back in.
6. When you hear a beep from the base unit system.
7. Let go of the end (find hs) button.
8. Your phone memory should be cleared now and you are ready to repeat the process of registering your base and additional handsets.
Anonymous
  • Posted on Nov 19, 2009
SOURCE: uniden 2080
I have same problem
Bill Boyd
  • 53816 Answers
  • Posted on Oct 30, 2017
SOURCE: once tried register uniden dect 6.0 . now it displays that put the handset in the base for registering. after that displays registration failed. menu is not working it displays put handset onbas
follow the user hand book exactly and it works
2answers
How to register the extra cordless handset of vtech 15250
Add and register a handset
Each newly purchased handset must be registered to the telephone base before use. When first purchased, each expansion handset shows NOT REGISTERED.
You may need to charge the phone first.
To register a handset:
    ·Place the unregistered handset in the telephone base or charger. Press Find for 4 seconds. If the headset screen doesn't light up after the 4 seconds. You will need to charge it some more.
    ·After making sure it is charged set the telephone on the main base again press and hold the Find button for 4 seconds ( until the red light IN USE comes on) Then release the find button. The headset will show PLEASE WAIT; this takes about 10 seconds to complete the registration. The hand set will show HEADSET REGISTERED and the headset number assigned, you will hear a beep when the registration is finished
    ·When the registration is complete, the newly registered handset is assigned the next available handset registration number. For instance, if you already have HANDSET 1 and HANDSET 2, the next registered handset is HANDSET 3.
    ·Makes sure no other headsets are in use at the time or the registration may fail.
    ·You cannot register a handset if any other system handset is in use. Only one handset can be registered at a time.
1helpful
How can i deregister a headset from my vtech phone model#ls6475-3. Also, is there a limited to how many headsets you can register to the base.
You can deregister all of the handsets and then register each one again for the LS6475-3. Make sure that all of the handsets are out of the base and all chargers and that the phone and all handsets are in standby. Then press and hold Find Handset on the base. When the In Use light begins to blink, release the Find Handset button. During the seven seconds that the In Use light is blinking, press and release the Find Handset button. Wait for the deregistration process to complete (about 10 seconds).
If the process fails, you may need to reset the base. You can do this by unplugging the AC power cord to the base or by picking up a registered handset and pressing Talk/Flash. Then you can try again. These directions are on page 5 (page 8 of the PDF) of the manual for the LS6405 handset. The direct link to this manual is https://cdn-media.vtechphones.com/media/p/document2/products/%7BD6DAD9B0-4C1A-4882-93D9-04124A59B629%7D/LS6405_CIB_V5_20160805.pdf . Then check that all of the handsets are in standby and not on any charger before attempting to deregister the handsets again.
You can register 12 handsets to the LS6475 base, according to page 31 of that manual for the main unit: https://cdn-media.vtechphones.com/media/p/document2/products/%7BA37C95FC-053D-4D34-B60A-EA5ED42B056C%7D/LS6475-3_UM_4_925.pdf . If you use the cordless headsets, you can register 10 handsets and 2 headsets.
These manuals can be found through the product page: https://www.vtechphones.com/pd/1603/LS6475-3-2-Handset-Answering-System-with-Cordless-Headset . The base manual is in the section under the Support & Manuals tab. The handset manual can be found from the Accessories tab. Then click on the Support & Manuals tab after clicking the link for the Handset.
I hope this helps.
Can't register handset.
Well I bet its because of the stand your using sometimes :P
I hoped i helped you! :D
2answers
How do i add another handset "uniden 6.0" phone to an existing phone and base unit of the same brand.I need the step-by-step instructions please. thank you!
First make to get a compatible handset.
For the Uniden D1660-2, the compatible handsets are DCX160 and DWX337. Make sure that you have not exceeded the number of handsets that the phone can support. The D1660-2 can support 12 handsets unless you use any DWX337 handsets. Then the limit is 6. (If you have more handsets, you will need to deregister some of them first.) Then allow the handset to charge. If the handset is reading "not registered", then place it into the base unit. You should see "Handset Registering" for about 30 seconds; then it will read Registration Complete. The manual for the Uniden D1660-2 is available here: http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/D1660-2om.pdf . This is the most common Registration for Uniden phones; there are a few exceptions (depending on the base or the replacement handset). Check the appropriate manual (see below to find the manuals).
For the DECT4096, press Menu on the base and then navigate to Handset Register. When you see Handset Registering on the base display, press and hold # on the handset to be registered until you see Handset Registering. (It takes about 2 seconds.) After the display changes to Handset Registered, check for dial tone.
On a few Uniden phones, there is a Page/Handst Register button on the base. On those you navigate through the Handset menu to Handset Register (Menu > Handset menu > Handset Registration). Then press and hold the Page button until you hear a beep. Then wait for the registration to be completed.
Most Uniden manuals are available here: http://www.uniden.com/scat/cordlessphones_mnl . Select your type of Uniden phone and scroll through the list to your model or use the search box to directly search for your phone and the manual.
I hope this helps.
1helpful
Only bass set going extra hand set not working
This is because the extra handset might have not been registered with the base unit.The headset should be register to use the headset with that base unit.
To register the handset to base unit please follow the instruction:-
On registration the handset is allocated a handset number for use on the new base unit, the handset numbers are 1-5.
1. Press and hold
d65e3ff.jpgon the base unit until 608a95f.jpgstarts flashing. Registration mode will remain active for approximately 3 minutes.
2.Press and hold both
19efd34.jpg together until you hear a long beep.
3.Select the base unit you wish to register by pressing the corresponding number button 1-4.
4. When PIN is displayed, enter the units PIN number (0000 for this model).
5. If the registration is successful the handset will return to standby mode in a few seconds.
Thanx
3answers
I have a handset that will not register. It was
if you press talk what apperars on the screen of the handset that will not register?
1helpful
Phones won't Register!!
It is possible that you have maxed all of the headsets that can connect to the base. Yes, the base can support 10 headsets, but there is a small chance that in some way you registered more to the base or you purchased a base that had phone registered to it that are not in your possession. Either way, if the base is maxed out, you will not be able to register any additional headsets to it. The only option is to do a factory reset of the base unit if this happens to be the case. This is done as follows according to Uniden Tech Support:
1. Disconnect the power from the base
2. hold down the following three (3) keys: [dnd] + [middle soft key] + [*]
3. While holding down the keys, plug in the base (hold the keys down until you hear a long beep). This is supposedly all it takes to reset the phone.
The way to determine the number of hand sets tied to the phone is to press the intercom key on the base and scroll through the list of phones. if you see more than the number you anticipate still being tied to the base, you will have to utilize the above procedure.
3helpful
I have a Uniden TRU8865-2 and I am trying to reset the base to clear non-exisistent handsets from the registry.
Unplug the power and phone cord from the base. Hold the find headset button and plug it back it continue holding the button until you hear a beep, then register the working phones.
12helpful
6answers
Tru9466 base and tru9465-2 handset
Same manual as lethean provided on a similar post but Page 24 if the previously used Base is Unavailable and your phone shows "Deregistration" in the Menu.
Base Unavailable (Handset Only)
To clear the base registration data in the handset, please follow these steps:
Press and hold [] and [#] for more than 5 seconds. Select the BASE UNAVAILABLE submenu.
BASE UNAVAILABLE appears. Move the cursor to select YES, and then press the OK soft key.
ARE YOU SURE? appears. Move the cursor to select YES. Press the OK soft key.
3helpful
Uniden DSS7955 Cordless phone problems
I had the same problem!
What you need to do is hold the "end" and "#" key for 5 sec, which will deregister the headset then all you would have to do is place it back in the base for it to registered again.
Top Uniden Lands Phones Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
