Both ends of the front roller does not have a screw or pin that which can be remove to slide the front roller..but both ends have small protruding knobs that sits inside of the welded brackets... does it mean that the whole frame has to be taken apart to get the front roller off?
How To Remove Treadmill Font Roller and Drive Belt Treadmill Doctor
Blessing
[email protected]
cell+whatsAPP:+50588611441
Testimonial: "the above youtube sites shows the front rollers with machine screws that can be un-bolted... however, the Nordictrack commercial ZS model's front roller do not have any screw(s) on either side but rather sits in the welded brackets on both sides...help!!!"
SOURCE: How to adjust door springs on this model dishwasher.
they are on the side of the unit there are slots on the side of the unit kinda tricky to get at. poss use pies of string or wire to pull it up on to the next notch. Dn load manual might have some illistrations in it? i have it somewhere email me. check website. does anyone know where i can upload my photos of this soap tray fix
SOURCE: Lens dropped and now it is tilted inside and won't focus
I had a camera with the very same problem and decided to take it apart. After all what was there to loose.
It sounds like you have more to do than I did. after undoing many screws I was able to take out the zoom lens housing. I was able to disconnect the motor from the main body. I also removed the CCD board.
I then removed the rear cover which housed most of the mechanics for the focusing and shutter operation. This was quite tricky as it is a very tight fit, and had to be wiggled out very carefully.
When I looked inside the main body I could see several metal pins which were wedged between the outer shell and the lens holder... a bit of force was required to seperate these. Unfortunatley the holders for the metal pins were broken, and there seemed to be nothing I could do. But I decided to try and super glue them in place. A bit of trial and error and i managed to get them all back into place. This bit is really tricky as there are several tracks for these little rods to fit into and not getting them right will make the lens not function.
Your model may be different but I suspect you will find that the metal rods which move the lens back and forth are loose and that the holders for same are broken. If you have a lot of time and patience you can get it working as I did mine.
Feel free to contact me if you need more info. (I knew I should have take some photos whilst I was doing it.
Regards
Thomas
SOURCE: Broken door knob. no access to hinges, screws. Rental property!
Take apart a similar doorknob in your house. Use the stem with knob on it and insert into the square hole in the lock--turn!
