Question about Icom Radio Communications
How to fix icom v68 with low volume? - Icom Radio Communications
Posted by Roger Capinding on
1 Related Answer
jeffreyclay
Jeff Robertson
SOURCE: ICOM IC-28H very low sound from radio even thought volume is max
I had a very similar problem on a hand held scanner. In my case the mylar speaker cone had separated from the voice coil. I found an exact replacement for under $4 at Allied Electronics.
Posted on Feb 16, 2010
Have an icom f5021 radio that will receive but not send.
Check Microphone settings and ensure volume indicator moves up and down when you speak into it.
Jan 06, 2018 | Icom Radio Communications
Why does my v68 icom radio display err-E on lcd
replace riibbon cable connected between cpu board and keypad board
Feb 10, 2012 | Radio Communications
Icom 7410 won't transmit in SSB works in CW and RTTY
I'd contact Icom, if its under warranty get it fixed
Jan 18, 2012 | Icom Radio Communications
A buzz accompanies transmission
Hi Richard
This is nearly ALWAYS caused by (A) A poor connection with cabling that is too small or long for the amp draw when transmitting, or (B) Low battery voltage or alternator output.
I'd check the power and ground cables first, and use a cable gauge at LEAST one size bigger.
Oct 24, 2011 | Icom IC-V8000
Jan 07, 2010 | Icom IC-R10 Handheld Scanner
ICOM GP-360ML GPS Receiver
I had this problem about a year ago. If all you need is the firmware update they will update it at no charge and they told me if it needs repairs they most likely will not have the parts becaus it is a discontinued model. They also said they did checked it and found no other problems. Sent it in to Icom:
Icom America
2380 116th Ave NE
Bellevue WA 98004
They did the firmware update and sent it back to me free of charge. It works great now and my chart cards work great.
Sep 09, 2007 | ICOM Informatique GP-360ML GPS Receiver
Radio Communications Logo
197 people viewed this question
Top Icom Radio Communications Experts
Vincent G
Vincent G
Ngoro
ray gallant
Are you an Icom Radio Communication Expert? Answer questions, earn points and help others
