SOURCE: Computer board shows UL even when very few clothes are in the washer
try to unplug and plug back after 30 seconds.
SOURCE: UL Code
Solved the unbalanced problem - open the top of the machine (press in with a flat putty knife about 3" in on the front on each side while lifting up as there are 2- 1" wide catches). Once both sides are unlatched, raise the lid then slightly lift the rear of the lid so that it fits into the curved part at the top of the hinges then open all the way - tape the lid to the top so it doesn't flap about and scotch the lid to keep it from falling back down on you. Now, look around - see all that rust? The rust has fallen into and gotten underneath one or more of the 4 white plastic suspension "ball joints" which have probably totally dried out by now from their factory grease because of the water, bleach, and rust particles. Having someone help you, simply lift up on one of the 4 corner suspension rods - gravity and weight is all that holds them down. The white ball will lift out of the socket and still be attached to the rod. Clean out the rust, lightly sand the "socket" with emery cloth, then slop in a fingerful of grease. I used automotive wheel bearing grease with graphite in it. Also scrub off all embedded rust on the white plastic ball. Lower that corner back into the newly cleaned and greased socket and repeat for the other 3 corners. Now when you move the tub around notice how the balls pivot in their sockets like they are supposed to. When they were dry and rusty they wouldn't move enough to allow the tub to twist like it should so it slammed around. Now, shake your head in disgust that after only 2 years there is so much rust that you wonder if it will make it another year before falling apart, close the lid, and try another load. That totally solved my off-balance problem where even a single handkerchief would give the UL error. It is still a finicky machine, but at least once again works like it did when new.
SOURCE: maytag bravos washer stops cycle "f" code flashes
This isnt really a solution because Im having the same problem. The repair man that came said that is buildup of soap in the water line. I use my own powder soap, not h/e, and its not desolving and getting built up in the lines. Im not sure what to do to get it to stop doing this. He suggested cutting back on the amount of soap and running hot water through the lines which I have done for the last couple of days but I still have this problem.
SOURCE: My Maytag Washer quiet seriouse
Hi
UL fault code indicates 'unbalanced load' which means the unbalance switch or control board may be faulty.
Sometimes it just means you have heavy items such as large towels or curtains in the wash but if it persists you will need to get it looked at.
Ash
Please rate this solution if you find it helpful
SOURCE: maytag bravo quiet series 300: Stopped at spin:
We have a Maytag Bravo Quiet Series 300 washing machine, the door latch is broken. I have the replacement part ( the locking mechanism) but I need can not figure out how to get the top of the washer to flip up to give me access to top front of the machine to remove the old part and replace it with the new.
How do I flip back the top (not the door) of this machine?
John
