Question about Polder Hardware & Accessories
Changing alert temperature on polder meat themometer
Posted by Doreen Hastings on
2 Related Answers
Anonymous
SOURCE: Polder 891-90 Where can I get
Polder timer manuals appear on following link:
http://www.polder.com/productinfo.html
Typical 891 manual:
http://polder.com.p2.hostingprod.com/images/instructions/891_instructions.pdf
Take a moment and vote on answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Aug 28, 2011
Anonymous
SOURCE: I have a polder digital thermometer with two
Timer is not identified for certain.
1) Some Polder timers have in-oven thermometer, and others say not to use thermometer inside oven.
2) The 12453 dual-sensor says inside-oven is ok
3) The 894 dual sensor says inside-oven is ok
4) TM360 dual probe says inside-over is ok
Can battery be changed on Polder instant read meat thermometer? If so,How?
Batteries can be changed on almost all instant read thermometers
go to POLDER.COM/ support/
then choose then choose
Thermometers
and then enter your model #.
This should take you to a detailed explanation. In general look at the unit and find the place to gently pry the cover apart. remove the batteries and replace with the same new style.
May 04, 2014 | Polder Home
Polder clock timer and stopwatch SKU E898 need instructions for
http://polder.com.p2.hostingprod.com/images/instructions/898_instructions.pdf
Aug 27, 2011 | Polder Triple Digital Timer Model 891-90
Polder kitchen timer instructions
Typical manual:
Jan 06, 2011 | Polder Triple Digital Timer Model 891-90
Lost Manual of 898-90 Polder Timer
Typical 898 manual:
Dec 09, 2010 | Polder Triple Digital Timer Model 891-90
I HAVE LOST MY POLDER THM-360 MANUAL. I CAN'T SEEM TO CHANGE THE TEMPERATURE. I PUSH THE +/- AND IT DOES NOT CHANGE. WHAT AM I DOING WRONG?
here's link to POLDER THM-360 MANUAL online.
http://polder.com.p2.hostingprod.com/images/instructions/THM-360_instructions.pdf
Nov 23, 2010 | Microwave Ovens
Polder 891-90 Where can I get an instruction manual for this meat thermometer Thanks
Typical 891 manual:
Oct 31, 2010 | Polder Triple Digital Timer Model 891-90
I have a polder digital thermometer with two probes--but I didn't get instructions with them.. Can I insert the probe in the oven with the meat cooking or use only with the meat out of the oven to test it...
Oct 30, 2010 | Polder Triple Digital Timer Model 891-90
I used my Polder meat thermometer in my gas grill. The fat off the meat cause flames to touch the probe. When I looked at the read-out it said 406 degrees F and then HI degrees F. Now it just reads HI...
It is possible that the therrmometer has over shot the limit set on it .It can be spoiled because the hat was in direct contact with the probe and has resulted in the failure of the unit.
Aug 27, 2010 | Microwave Ovens
The dash needs to be moved back. The dash is
Replace it, as there is no adjustment. Get o good used one , use a sunshade and never use armor all on it. That will cause them to shrink up. Put a meat or cooking themometer on the dash and leave car in the sun. The temperature will surprise you.
Jun 26, 2009 | 2001 Buick LeSabre
Hardware & Accessories Logo
452 people viewed this question
Top Polder Hardware & Accessories Experts
Gene Haynes
Terry
Terry
Attique-ur-Rehman
Attique-ur-Rehman
Are you a Polder Hardware and Accessory Expert? Answer questions, earn points and help others
