SOURCE: i have an admiral microwave model 8573
That's made by Sharp and many of theirs (and other brands) require you to take the outer cover off to change the bulb. Here's how: Unplug the oven first. That's rule one! Remove all of the screws from the side and back of the outer wrapper / cover of the microwave. There are usually four on the rear edges and two on the bottom of the edges on each side of the cover. The cover then should be slid slightly backward then up from the rear and it will slide off. You may have to pat down on the sides to loosen it first. I use firm and simultaneous open-palmed slaps on both sides near the front, then pull it up and off. It is possible that some voltage will remain on the high voltage capacitor and can be conducted via contact with wires, connectors and components connected to it. If you stay away from all the wiring in the right rear (as you're looking at the front door) it should not be a problem. Unless there is a problem, the voltage should actually not be present. If you and the work area are clean and dry, and you only touch the light bulb while the cover is off, there should be no problem. Change the bulb. It may be held in with a bit of clear tape, too, so take a look at the socket first. When putting it back on, be careful that the inside front edges of the cover catch properly in the slots in the chassis. Good luck and be safe! Make sure it is unplugged!
SOURCE: glass on front door of
If its not too old, try sears.com
They carry many parts and if not there try apwagner.com
SOURCE: usermanual for old ADMIRAL dishwasher model number BDUR 41400
right. first of all there are usually three settings one is intence 2 is normal and three is pans. or the other way round. cannot remember. but put nothing in and turn it on by closing the door. turning the knob and pressing the start button when selection is made if no button to start it just select a program and see which one lasts the longest thats the pan one. use dishwasher tables either in the little basket hanging in there or in the door there is a slide thing. put tablet in there and fiddle till it stays shut. then close the door. after loading with stuff. at the bottom will be an unscrewable white knob put some dishwasher salts in there every few months. it keeps the water soft. there is also a filter in the bottom you can lift out to clean a round thing within a mesh grid. that must be reg checked for bits of dinner and stuff. try and get the bets off first. dont put beans and things left on plates and pans in cloggs up. try contacting supplyer for instruction manual. if you cannot thats all you need to know really. hope that helps. liz
SOURCE: Need a user manual for
First of all, here is a direct link to the ONLINE USER'S MANUAL for that model:
http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316137230en.pdf
And here is a link to the wiring diagram for that model:
http://manuals.frigidaire.com/prodinfo_pdf/Springfield/5995451720.pdf
And here is a link to the installation instructions:
http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316137233en.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
I hope that was helpful to you, good luck.
If you choose to rate this solution using the Thumbs Up scale provided, I thank you very much for your time and consideration.
Joe.
Try to identify your scope here
http://www.meade.com/product_guide.php
then get a manual from here
http://www.meade.com/manuals/index.html
