Question about Cambridge Soundworks Audio Players & Recorders
SOURCE: Fluctuation in sound output on Cambridge Soundworks 5.1 speakers
Hi Paulus
A lot brand of speakers, like Sound Blasters, Logitech, Cambridge, has this (strange) kind of volume problem, sometimes, is the resistor, in the volume control, sometimes in the modulator for the board on the sound speakers, Subwofer.
I use a general tip is let the volume in one setting and don't move in the intermediate low volume say....9 .
from other thing, be change the speakers.
Posted on Nov 26, 2007
SOURCE: cambridge soundworks speakers
Happy Holidays Fredonna
Well, easy task, just put a music CD, on system and if you got an headphones, put in the green connector on your sound card, pop up the PC volume, and see if you heard sound, if you do, heard sound then the problem is your speakers. if don't is your sound card.
good luck
Posted on Dec 26, 2007
SOURCE: We unplugged our cambridge soundworks 765i and
I had a similar problem. I called campbridge soundworks and they told me to unplug the unit overnight-and then when I powered it back on to press the power on key 10 times. IT works then.
Posted on Nov 28, 2009
SOURCE: Dim display on Cambridge Soundworks 88CD
I can't find a manual for this but my guess would be there is a setting for the Display to dim it at all times unless you touch a control.
Posted on Feb 26, 2010
SOURCE: Two CDs stuck inside Cambridge Soundworks 765i
I have the same problem. Did you find a solution? Thanks.
Posted on Aug 22, 2010
