Peel the beginning edge of the paper roll off of the rest of the roll. It will be lightly glued to the roll to keep it from unwinding.
Cut the end piece of the paper if it tears when you pull it off of the roll. You want the edge to be the same level all the way across so that it will feed into the machine easily.
Flip the paper holder bar away from the Unisonic adding machine and slide the paper roll onto the bar. You want the paper on the roll in a certain position. Make sure that when the loose edge of the roll is on the bottom, that it is facing in the direction of the machine so that you will be able to pull it toward the machine to feed it in.
Pull the lever up that is located near the paper slot in the back of the adding machine.
Take hold of the edge of the paper and feed it into the paper slot.
Put your finger on the paper roll-up knob and spin the knob toward the back of the machine. This will turn the rollers inside the machine and push the paper up. Stop turning when you see the paper come through and above the cutter.
Cut paper at a 45 degree angle and load into back slot with angle (apex) of paper to the right of machine when facing it. Be sure to push it thru when loading. You should see tip next to calculator number wheel. Hit the additon sign several times to advance. You may need tweezers to pull paper thru if it doesn't advance by itself.
try this otherwise see the manual and make sure you are not using generic paper roll only use specific paper because the Chinese knock off paper is to thin
