SOURCE: Ice Maker
Sassy, the red led should flash 2x followed by a pause, repeatedly with the door open. If you hold the left side flap down, it should stay on steady. If it does this you know the optics are ok. Sounds like you just hooked it up to water. The ice maker thermostat has to be at least at 17 degrees before it will call for water and then it will have to prime the lines to the ice maker first before filling the mold. The easiest way to reset the icemaker is to unplug the refer for 30 seconds. Other things you want to check are that the ejector blades (blades that push the ice out) are in the 2:00 position. Check to see that the fill tube that fills the mold is not frozen over. I have a feeling that your lines just needed to be primed. Hope this helps you understand this unit a little better...Catriver...post back.
SOURCE: icemaker not making ice
First thing to check is to see if the optics are working properly. This is the red flashing light on right hand side of freezer wall. Close the flipper door, be sure not to block the beam, and the light should go to solid red. If it does then the optics are ok. If it continues to blink then that is your problem. If optics check ok then pull ice maker out and remove the white plastic cover. It just pulls off. Look at the center of the gear wheel and see if one of the plastic tabs is either broken or if they are sort of twisted and touching eachother. If any of these things with the gear have happened then that module will need to be replaced along with the ice maker thermostat. If your not sure how to replace these parts then just replace the whole ice maker. That is much easier and not much more costly.
After changing the parts or the ice maker out follow these steps to start the ice maker thru a cycle. 1. Remove the ice maker from the cradle but leave the harness connected. Remove the front cover from the module. Unplug the refrigerator. Get a small jumper wire with bare ends and jump T and H on the module, leave the jumper in and set the ice maker on the shelf. Close the door. Now plug the refer back in and wait 30 seconds. Open the door and the ice-maker should be cycling. Remove the jumper, put the module cover back on and set it back in the cradle. The fill should take place when the ejector blades reach the 12:00 position. Follow these steps exactly in order
SOURCE: Kitchen Aid Ice maker Stopped working
I would suggest not buying a KitchenAid. I have the same problem with my ice maker. Have had nothing but problems with every KitchenAid product that I have ever owned. I will never purchase another KitchenAid product.
All of there appliances are second rate. That is "The KitchenAid Difference"
The ice maker has stopped working. The red led light blinks when the freezer door is opened. Any thoughts?
SOURCE: kitchen aid ref, ice maker quit making ice
hi my name is mark, do you have a water filter on this unit. shut off water to ice maker. remove water line from ice maker, hold water line in a bucket slowly turn on water. if you get water. then the fill solinoid has failed. if you do not get water trace water line back to water shut off. if it is the solinoid valve. you will need model and serial number to order part
