Question about Frigidaire Ovens
My frigidaire electric oven turned itself off
Posted by Craig Osmond on
1 Related Answer
jmgldsmth
Jim Goldsmith
  • 2005 Answers
SOURCE: Frigidaire FEB27T5D Electric Dbl Oven oven does not get hot
replace the upper oven calrod element it is an easy job just unplug the range turn the range around remove the back plate loosen the element wires from the element remove the element from the front any parts supply will have your replacment part such as www.applianceparts.com
Posted on Apr 26, 2009
What will make a oven come on with the oven knob turned to the off position?
Maybe your knob is turning but the rod the knob is connected to is not turning. Best to remove knob and turn the rod to off position with Pliers to be sure it is actually being turned to the off position.
Jan 15, 2018 | Frigidaire 30" Self-Cleaning Freestanding...
The fan continues to run. How long and will it automatically shut off?
The fan you refer to should be the fan in the oven cavity. It removes hot air from the oven cavity and expels the air out the front of the oven. Once the oven is turned off the fan will continue to operate until the oven cavity has cooled sufficiently. It may run for 10 to 15 minutes and will turn off by itself.
Feb 12, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
The stovetop works but the oven itself won't heat up... help?
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Dec 14, 2010 | Frigidaire GLEB27S7A Electric Single Oven
Door will not unlock
The door lock mechanism may be bad. Take off the back and you will see the mechanism in the middle above the oven (long rod to door) Try turning by hand after a slight movement it may go by itself. If not turn till door opens and replace.
Nov 17, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Oven not heating
If the element only works partially or not getting red hot at the "Hi" setting, the problem might be with a burned out receptacle that the element plugs into. If this is the case, replace both the element and the receptacle.
You can usually tell when the element itself burns out. It might have small holes or bubbles on the coil. Replace the element, if found defective.
Jun 22, 2009 | Frigidaire 30 in. Electric Gallery Series...
Apr 26, 2009 | Frigidaire FEB27T5D Electric Double Oven
Lost manual to my electric oven, how do you clean inside of oven?
Make shure every thing is out of the oven, and that the door is well locked, then hit the cleaning button.
the oven will clean itself with high temperatures.
HEre is a manual for a frigider oven, should be not too different from yours.
Nov 20, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Oven electric
i have a frigidaire elite convection oven,older, the elements work but the convection oven will not turn on - what should i check?
Jan 13, 2008 | Frigidaire FEB27S5A Electric Single Oven
Ovens Logo
384 people viewed this question
Top Frigidaire Ovens Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Kell Le
Level 1 Expert
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
