SOURCE: i dont know were the disk is ment to go for my floureon H.264 digital video recorder
https://www.youtube.com/watch?v=U9QmU5Qem9A
SOURCE: floureon h.264 error code cab557
there are a few things you can do. reset the unit in main menu ie right click on mouse and click on main menu, in setting click on reset. it will go back to settings as new and should sort the problem out other is, is there a hazard triangle lit up on front of the unit. there should be power, hd and a cam sign showing no others showing. if the triangle is showing it could be a fault with a camera or the hard drive. also if you have 3 cameras working only it will show a triangle. let me know how you get on.
SOURCE: How I make factory reset for sentient H.264 standalone dvr
There are two methods to reset.. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the device from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand devices are given. Never forget to exit the service mode, after all adjustments have been done.
SOURCE: account unlock code for my floureon H.264 network/ dvr ive tried everything
if new leave blank and press ok
