Question about iLO Televison & Video
Ilo tv hdmi wont work from computer - iLO Televison & Video
Posted by Jon Storey on
2 Related Answers
Benimur
Louie Role
  • 6966 Answers
SOURCE: ilo 27 inch hdmi/dvi hd tv monitor
Hi, I'm afraid that not only a cable is needed but an analog (vga) to digital (dvi) converter/scaler as well. The iLo LCD Display V27DMBX-U12 can hook up to a PC using the DVI-I connection only. As you said, your computer has the standard 1D15 pin VGA connector. Another possibility is if your video card has a composite video output (normally a color yellow RCA female) or an S-Video output which will both connect direct to your iLo LCD Display V27DMBX-U12. For the RCA connection all you need is an ordinary RCA to RCA shielded wire cable and for the S-Video, an S to S Video cable will work. There is of course the question about the quality or the resolution. Good luck and hope that this be of some help to you. Pls post again how things turn up. Kind regards.
Posted on Jul 31, 2007
Anonymous
SOURCE: ilo 27inch hdmi hd tv monitor
You would need to connect a VGA + Audio to HDMI Converter. The downsize it the converter goes for about $150 us
Posted on Apr 12, 2008
Ilo 2600 HDTV manual
You would need a converter to make it work. Adapters won't work as the type of signal would need to be changes. Your best bet would be to purchase a DVD player that has outputs that work with the tv. Sorry.
Jul 07, 2016 | iLO 2600 Television
I have an ILO HDTV. I try to change the station with the remote but the TV only changes the station between 2 and 22. It doesn't respond to my commands when I want to place it on channel 3 for my...
My ILO TV has a source selection that can select where the signal input is coming from that I want to display. Do you have the sat hooked up to an HDMI input? If so try selecting that. If you do have the option of using HDMI - buy a cable and hook it up between the sat (assuming it does support hdmi) and the ILO (mine does, and it about 5 years old). This is the least problematic way to make it work.
The Poodle Guy!
Nov 21, 2010 | iLO 2600 Television
How do i hookup my ilo tv monitor to my computer?
ur VGA card must have video out jack of any type latest cards have HDMI that would work with any new LCD TV
Sep 22, 2009 | Televison & Video
CANT USE DIGITAL TV OR HDMI MODE - SCREEN NOT SIZED
Give FUNAI a call they can walk you through the problem. There info is...
FUNAI CORPORATION Customer Service
Tel :1-800-605-8453
http://www.funai-corp.com
Feb 15, 2009 | iLO IWT3206 TV
HDMI ON ILO 32HD
it sounds like there is a problem with either the output on the PS3 or the input on the circuit board of the TV. I would try a reset on the PS3 first. Also make sure that there are no other video or audio cords plugged into the PS3 because this will cause the PS3 not to send the signal via the HDMI.
Mar 14, 2008 | iLO 2600 Television
ILO-26HD Audio & Video
I have a ilo 26 lcd tv with built in hdtv tuner and I have a red line down the center of the screen that started today. t
Feb 06, 2008 | iLO 2600 Television
Ilo 27 inch hdmi/dvi hd tv monitor
Jul 31, 2007 | iLO V27DMBX Television
Ilo 27inch hdmi hd tv monitor
Connection to a computer
This TV has an HDMI interface, not DVI. If your source is DVI, you can get an DVI to HDMI adapter. The HDMI carries both video and audio data, so you will need to connect your audio separately.
May 10, 2007 | iLO 3200 32 in. LCD Television
HDMI->DVI cable won't work
Get another cable box, the scientific atlanta are notorios for these type of problems
Mar 26, 2007 | iLO 2600 Television
Televison & Video Logo
Top iLO Televison & Video Experts
Lee Hodgson
Lee Hodgson
CoppellTVRepair.com
matt martin
matt martin
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
