HTS3569/98 philips dvd home theatre system
SOURCE: Philips LX3600D Home theatre always returns to standby mode
There is a 1ohm resistor on the 4x4 pcb as soon as you take off the cover. ( I forget the ID # ) It supplys the -15volts to the control bd. The resistor will not looked burned. It was under rated. An ohm meter will find it ( open ). Rreplace it with a 1/3 watt. I believe the orig. was a 1/4 watt.
SOURCE: Home theatre but TV without audio outlet
I would suggest that you smash
Philips HTS w/a hammer!
I had better sound from TV alone! Only 2 speakers put out sound from TV. Recordings from DVR can not be heard very well w/all volumes at max. System sucks! You get what you pay for! $2500 LCD TV sounds worse w/Philips HTS than my son's $300 TV! ALL cables hooked up as instucted!!!!
SOURCE: Corrupted Firmware on Philips HTS3555 Home Theatre System
Only posibility is finding a service shop that services Philips....
SOURCE: I need pinout assignments for a Philips 5.1 Home
Pin assignment is as follows (not sure of levels required- preamplification / attenuation may be necessary:
1: Control 0/5V.
2: Unused
3: Unused
4. Center speaker in
5. Ground
6. Ground
7. Subwoofer in
8. Ground
9. Unused
10. Ground
11. Left Front speaker in
12. Right Front speaker in
13. Ground
14. Right surround (rear) in
15. Left surround (rear) in
SOURCE: Hi, I just bought a Philips
Ok my situation is similar-i did exactly as u described here bobhifi and it worked initially . Then after some weeks suddenly the Aux display now shows 'AV1 Coax' and no sound is coming out of my LG DVD speakers except under Tuner and DVD modes. Pls help
