Question about Boating
Is there a fuse which operates a fuel pump on a skicraft E20 boat
Posted by Darren gordon on
Kardoc
    Top Expert:
  • Boating Master
  • 5,889 Answers
My machine comes up E20 towards end of program what does this mean
Really need the make and model of your machine as different manufacturers use the same code to mean diferent things. Hotpoint/Indesit/Creda generally use E20 to mean there is a problem with temperature sensing (Which generally indicated that the water heater element has failed. Zanissu/AEG Lavmat use E20 to indicate that the empty pump is blocked (Usually behind a kick plate at the bottom of the machine or a flip open door, you will find a cover that looks a little like a fuel cap). AEG also use E20 to indicate a door lock fault on some models. Personally, the fact that it is near the end of the cycle would indicate to me you have a blocked empty pump
Sep 26, 2015 | Washing Machines
2003 Yamaha outboard HPDI will start but will not
Many possibilities. Mine had been sitting. Old fuel in HP fuel pump reservoir was clogging HP pump. I was able to disassemble, soak and clear pump and get running. New pumps, big money. My boat, twin 150 HP HPDI
Sep 23, 2014 | Boating
Nissan Pintara 1986 no fuel pump operation could not find power & earth at fuel pump Could it be fuel pump relay ?
Hi, First thing to check is the fuses that may be problem. If the fuse is okay then check for the fuel pump relay fittings. Please leave me feedback thanks, Malcolm Campbell.
Nov 14, 2011 | Nissan Z Cars & Trucks
Zanussi turbodry 1200 There was a first error message E20, while drying, so i stopped the proccess but now in a new washing cicle, i´ve the same error while filling Whatt is E20? what must i...
Hi
Error code e20 means a clogged drain pump. This might have happened due to small clips, pins, coins, etc being stuck in the pump. Please note that error e20 can also occur when the drain pump is not pumping fast enough or when the pump fails. To fix the issue you'll need to check the drain pump. Tilt the machine on its side and remove the 3 screws and 2 wires that hold the pump in place. Hope this helps... Please post back for any further assistance.
Daniel
Nov 16, 2010 | Washing Machines
I have an e20 error code on my 1990 cadillac sedan deville. What does that mean?
E20 means open fuel pump circuit could be failed fuel pump relay
Aug 18, 2010 | 1990 Cadillac Deville
What does e20 mean? The display shows an error of e20. Looks like the water is not pumping out during the regular wash.
Hi
Error code e20 means a clogged drain pump. This might have happenned due to small clips, pins, coins, etc being stuck in the pump. Please note that error e20 can also occur when the drain pump is not pumping fast enough or when the pump fails. To fix the issue you'll need to check the drain pump.
Remove the 2 screws from the bottom of the front access panel, it will come off. Now check for the pump on the right side and remove hoses from it. Remove pump from machine then remove whatever is there in the pump.
Daniel
Jul 31, 2010 | Frigidaire ATF6000ES Front Load Washer
E20 message want spin
E20 is not an exact error code. It's indicating a possible pump out problem. Here is a few possible causes of an E20 error code:
1. Restriction in the drain pump
2. Failed pump
3. Water not pumping out fast enough (crimped drain hose)
4. Too many suds ( too much detergent or wrong kind)
5. Pressure switch (not communicating with control board)
6. Loose wire at pressure switch
7. Loose wire at pump or control board
8. Failed control board
Apr 29, 2010 | Frigidaire ATF6000ES Front Load Washer
40 Hp Johnson outboard motors stalls out after a few minutes running then takes forever to start again
May likely be one of two problems:
1. Fuel flow: Make sure fuel tank vent is open and not blocked while engine running. Check primer bulb is working and no air leaks along hose anywhere. Check function of fuel pump and ensure fuel is getting to the cylinders.
2. Overheating: Check engine isn't overheating and that water pump is operating properly while engine is running.
Sep 17, 2009 | Boating
Boating Logo
131 people viewed this question
Top Boating Experts
ray gallant
 vpsoccer
vpsoccer
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
