Televison & Video Logo
Question about Vizio Televison & Video
Vizio 65in Model D65u-D2 I have a black screen with sound.think it may be led driver but i can change format to small and take off HD channel and it will stay on. would this still be the led driver?
Posted by Wendy Davis on
  • Wendy Davis Dec 14, 2017
    So should I start by replacing the main board?
Larry
  • Vizio Master
  • 4,627 Answers
Most likely not...sounds like a software issue to me
Posted on Dec 13, 2017
5 Related Answers
Anonymous
SOURCE: Vizio 50" Plasma HD
just purchased 2/7/08 Model # VIZIO JV50P HDTV 10A followed instructions to install cables but when turned not allowing me to do initial set up. Can't access menu from remote either PLEASE ADVISE. ....MO
Posted on Feb 09, 2008
Anonymous
  • 3 Answers
SOURCE: my 47 in vizio lcd tv. the zoom/widescreen
the LCD TV is overheating. Solution A) allow air circulation. B) set up a small fan behind the TV C) once the set is cooled down save your preferences
Posted on Apr 05, 2009
Anonymous
  • 59 Answers
SOURCE: Philips HD tv has no picture
common fault this , normally the fuse has failed on y-main board due to shorted thick film unit
unfortunately its not a cheep repair job.
Posted on Aug 18, 2009
Anonymous
  • 1284 Answers
SOURCE: vizio pixelation in hd nt all channels
Usually a TV that pixelates only on some channels is a problem with the signal levels coming into the TV or the cable box. If you are using a cable box then definatley the signal is the issue..
Posted on Nov 11, 2009
Anonymous
SOURCE: Vizio VF551XVT 55' LCD LED HDTV no sound on HD
I have the same problem. I even returned one of these tvs and the same problem exists.
Posted on Mar 26, 2010
2helpful
Vizio D65u-d2 Backlight not working after replacing 2 LED strips?
You should be able to replace just the bad LED strips however with as much work as it is to get the set apart and back together I always replace all them as other strips generally fail in time. Did they all light up after you replaced the bad ones before you put it back together? This model set has local dimming so servicing it is a bit more complex, you could have a bad backlight driver but that board seldom gives issues, also you could have main or power board issues as power for the backlight driver comes from the power board or you could have main issues as it's the signal from there that turns on each strip.
2answers
Model d65u-d2. Why does it have a black screen?
only an educated guess back light is the problem , might be power supply of the led strips call a local repair shop
Hi, I have Vizio d65u d2 Screen goes black after 3 minutes, I change power board supply and led board, but still same problem
Hello
Make sure the connectors are snugly in place and that the set in not i a position that stress the boards, reset all settings then
change the picture mode to standard and auto brightness to medium
Good Luck
Mr.Mike
Why is my D65U-D2 Vizio screen going black?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main digital board./
Top Vizio Televison & Video Experts
Marvin
Marvin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
