Question about Sony Audio Players & Recorders
Sony LBT - N600AV with TC -N500 twin cassette deck Tape was jammed in machine, have now been able to remove tape however playing mechanism is stuck in playing position and door fails to open or close.
Posted by Martin Knapp on
5 Related Answers
Anonymous
SOURCE: Cassette Tape stuck
How does one take the cover off?
Posted on Feb 02, 2008
Anonymous
  • 579 Answers
SOURCE: Left Deck Door Stuck Shut on Cassette Deck
The cassette mechanism has a large gear that rotates to different positions for the different modes. On time around is a play - stop cycle. It is stuck in one position and won't come around to the stop spot. Need to take the cover off and help it to turn to get the cassette out. Then figure out if something is wrong preventing it from turning or if the wheel driving it is the problem. They are all a little different so this is where your mechanical apptitude comes in.
By the way, you'll figure out right away they don't intend these things to be fixed.
Hope Ya Fix It.
Posted on Feb 10, 2008
Anonymous
  • 142 Answers
SOURCE: Marantz Cassette Deck Model Sd 35 Tape door will not open
It sounds like the drive belts on the deck have broken (not allowing playing, FF or REW) and/or the tape got "eaten" meaning the tape itself has wound itself around the rollers and cannot free itself. I strongly doubt this is an electrical issue. Definately sounds mechanical.
As far as the door not opening, there's usually a hook that holds the door closed. If the unit is mostly disassembled, look near one of the sides of the door for a metal hook. It's normally spring loaded and can be moved manually. That should free the door. If your tape was eaten, it might take some gentle persuasion to unwrap it from the rollers.
Good luck.
Posted on Mar 13, 2008
Anonymous
SOURCE: Sony dual cassette deck TC-WR535
i had the same problem of not opening the cassette doors and not running with my sony tc wr535. After I repaced the belts myself with new ones it did run fine! :-) An original sony(!) rubber belt set for the two decks costed me 23 euroos incl pp.
Posted on Jul 11, 2008
Anonymous
  • 242 Answers
SOURCE: Sony TC WR565 dual tape deck. Both doors will not
you can not fix it without tearing it apart. if you do take it apart, try to get the front panel off. Hit the eject button and look for a lever that is stuck.
Posted on Jun 28, 2010
Cassette drives will not play
You may have an issue with the cassette deck on your Sony LBT-D550. The cassette deck uses a belt drive system to operate the cassette mechanism; if belts are broken, it can cause the deck to malfunction.
All the belts may have failed at the same time, but it's also possible that there is another issue causing the problem. Some possible causes of a cassette deck malfunction include:
  • A problem with the cassette mechanism itself, such as a jammed cassette or worn-out gears.
  • A problem with the cassette deck's motor, which a malfunctioning capacitor or other components could cause.
  • A problem with the cassette deck's control board, which a malfunctioning switch or other components could cause.
To determine the cause of the problem, a professional technician should look at the cassette deck.
3answers
Hi what has happened is when you pressed play the tape head that reads the tape has come up as normal this locks the door as you cant open it when its playing but instead of the tape head releasing and going back down into start possition it has become jammed in the tape itself.
You have two options turn off at mains and give it a gentle bang a couple of times this might free the tape and let the head go back to start possition its upto you how hard you tap it but doing this usually works and will allow you to get the tape out failing this then its going to be a case of stripping it down till you can get access to the tape head and be able to free it from the tape allowing door to open let me know how you get on ok and if you need further assistance
Sony TC-138SD cassette deck starts to play then stops after 3 secs. Same when trying to rewind/fast forward
It sounds like the belt is slipping or broken which monitors the speed of the tape movement. When you play or rewind the tape, it thinks the tape has reached the end of play and shuts off. You can try a different tape to make sure the tape does not have too much tension on it. If the second tape has the same result you will need to remove the top cover of the deck to inspect the tape drive mechanism. Make sure the belts and pulleys are clean and replace any belts which have glazing or cracks. If the belt is broken you will need to replace it with a compatible belt of the same length and width.
2answers
A cassette has jammed close the A door of my Sony TC WE675. How do I clear the jam? The tape is probably keeping the door closed.
Please click HERE so that you will be directed to the site where you can troubleshoot the issue.
I hope that this will work for you.
3helpful
2answers
Cassette stuck in Sony TC-K611S deck
Rotate loading gear with your finger until mechanism released and set on stop position. press eject button and take out tape.
2helpful
Sony Stereo Cassette Deck TC-WR550Z
Drives belt has become too slack to drive mechanism properly or the drive motor is bad. Have unit serviced for new belt(s)
5answers
Cassette Tape stuck
Try pushing the eject button while pusshing the power button. Mine was doing the same and that is how I was able to eject the tape.
Good luck
sam
Open Questions:
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Morne Olivier
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
