Hi Kevin search through all your paper work, any repair order sheets from dealers hand books etc. If no joy you will have to go to Holden's there are far too many codes used to be able to offer any specific one for your radio. The Dealer may be able to obtain the code on your behalf. There will probably be a charge. Good luck
SOURCE: broke left hand side exterior electric mirror on
I think I can explain it easy enough with no diagrams as this is a simple enough job.
Regards,
Tony
SOURCE: my high beam lights & parking lights work, but not the normal lights.1985 holden astra!
By "normal lights" I assume you mean "low-beam headlamps"? If this is true, then you may either have burned out headlamp bulbs or a faulty low-beam headlamp relay or relay circuit.
Testimonial: "Thank you for your assistance. Burnt out low beam headlamp bulbs was the problem. They said it was unusual for both to go at the same time, but that's how it was. Your help was greatly appreciated. "
Opel astra ,never a problem with these excelent cars ,now is it a seat belt stuck or a seat stuck forewards problem as the question is a bit conflicting .
SOURCE: I need a radio code for my holden astra
Does anyone have any tips for obtaining the radio security code in an Astra without having to fork out the $25 - $33 being quoted by all the Holden dealers i've contacted?,
Thanks
