Hello Stephanie Sakata,
I found 2 (two) "TOTALINE" manuals...
These little beauties all work pretty much the same...
Put the slide switch in HEAT MODE...
Push the "HOLD".. (which keeps any/all
clocks/gadgets and BACK-SETS off)...
and ADJUST THE TEMPERATURE where you want it...
ELSE...
Read these manuals (close)...
No exact matches found Try these results
Carnac the Magnificent
SOURCE: base unit screen blank and handset has search 1 lit
Wrong phone details given to you, problem sorted
SOURCE: lost intruction manual Magic Steam Press csp-1
Follow the link or copy it to your browser - http://www.singerco.com/accessories/manuals.html - and search for your Singer.
Kind regards
Ryno
SOURCE: Totaline thermostat display is blank. Unlock steps
If a Total Line tstat is blank two reasons No power bad tstat. Rus
SOURCE: need a Totaline thermostat P/N 0441 Owner's Manual
Hi, if you don't have the manual for you're T-sat, chances are you will not find one.You could get lucky, but I would post this information on a site like www.craigslist.com. You may get help on this site
Good Luck,Sincerely,
Shastalaker7
