Question about Locks & Locksmithing
I have KABA 780 FDU. how to change time in it. guest key cards get expired hour before then check-out time.
1 Related Answer
Doc Sawyer
  • 10 Answers
SOURCE: Lost GMA Card for Kaba
When you set up the system, you should have made at least 3 GMA's. Hopefully they did that and there are two other GMA's in a safe place. We keep ours locked up with the other key masters.
If you don't have any GMA's at all, you will have to call KABA. They will give you a reset code to reboot your FDU and then you can make new GMA's. You will have to remake all the other cards as well. It will be like starting over.
Good luck.
Posted on Aug 03, 2011
Unican front desk unit 780 is not reading any key except grand master. what is the reason we cannot make any guest key
Sounds like someone has deleted or changed other employee I.D. information and disabled their cards.
Nov 22, 2017 | Locks & Locksmithing
KARA ILCO FRONT DESK UNIT 780 SAYS READER ERROR OR INVALID CARD, CAN THIS BE CLEARED BY RESETTING?
We have 2 front desk units Kaba ilco 780A1, one of - Fixya
www.fixya.com/.../t4588452-2_front_desk_units_kaba_ilco_780a1_one
Apr 19, 2010 - Question about Simplex Kaba Ilco Unican 1000 keyless lock ... the grand master authorization card is swap it shows a message that says ''reader error or invalid keycard''. .... How to reset grand master keys front desk unit 780.
Hotel Lock - Front Desk Unit - Kaba
www.kaba.co.uk/68244/front-desk-unit.html
Kaba GroupMulti-track keycard encoding and reading; Drop and swipe reader track with ... Front Desk Unit brochures can be found on the Sales and Support page.
Dec 25, 2015 | Locks & Locksmithing
How to change core on simplex 1000
Get the complete installation instructions as a PDF download from here:
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=13
On this grid, across from "1000", click on PDF under the "Manual" column. If you cannot open the download, you will need to download and install Adobe Reader--there is a link in the upper right corner of the download grid.
You may also need a DF59 key and spanner wrench to change the core. Order part number 20127800001 ($9.00) from Kaba Ilco.
In fact, I'd call them before starting the process for technical advice:
Technical Service Dept.
For further information at (800) 849-8324
or (336) 725-1331.
They are located in North Carolina, so the best time to call is probably during east coast business hours.
Good luck--and please provide feedback if this helps!
Oct 12, 2011 | Simplex Kaba Ilco Unican LP1000...
Code dont work,key rod dont seem to work,cant change code.
Yours is an unusual problem. Therefore, I suggest that you call Kaba Ilco during regular business hours for assistance. Toll free: 800-849-8324 Be sure to have the model number and any other pertinent info on your lock ready if you call.
On the net:
Customer service can be contacted from this link:
http://www.kaba-ilco.com/access_control/support_contacts/service_and_support.aspx
Tech Support from this link:
http://www.kaba-ilco.com/access_control/support_contacts/technical_support.aspx
1-800-849-8324 (option 3, and then option 6)
Aug 11, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
Lost GMA Card for Kaba ilco 780 FDU. How can i get another?
Good luck.
May 17, 2011 | Office Equipment & Supplies
How to extend or reprogram kaba machine expired date for authorised master key?
I can't help you directly, but I will steer you to further information.
You will find a link to download the manual for your model on this page:
These are PDF files, requiring Adobe Reader to open. There is a link on the same page to download Adobe reader.
May 11, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
When trying to reprogram a room key for entry, the initialization process works, but after you initialize and a green button appears, we connect the kaba to the door, but when we slide the card it says...
Contact Kaba Ilco directly with your problem.
or (336) 725-1331.
Jan 22, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
Grand master authorization cards expired , can
i really like this article..i just want to appreciate you for this work..and i would like to read more article on this...card master
Apr 14, 2010 | Simplex Kaba Ilco Unican 1000 keyless...
Locks & Locksmithing Logo
2,397 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
