SOURCE: Panasonic workio DP-3530 error code E01-20
e1-20 means " laser unit horizontal problem" its ether your lsu is not connected or defection or you spc board is not connected or defective.
good luck
SOURCE: error code c440
Hello sir; C440in this machine,it means fuser unit problem, but it can be reset the procedure as follow;
1, hold down "0" and "8" keys while turn on the power.
2, enter 400 press start.
3, enter 0 press set or enter.
SOURCE: Print driver for Toshiba E-Studio 3511 Copier/Printer for Window
You can go to http://copiers.toshiba.com and download it.
SOURCE: Error code C380 paper feed failure
c380 indicates auto-toner error for black developer (K).
Check following:
Is the harness between the LGC board and the developer unit drawer connector open-circuited?
Is any harness inside the developer unit or the auto-toner sensor harness open-circuited?
Is the auto-toner sensor connector or the connector CN341 on the LGC board disconnected?
IF connector no problems, then u probably need to replace the auto toner sensor.
SOURCE: Error F120
Hello sir; The error code you display F-120 it means "data base" problem it can not be reset you have to replace either memory chip or hard drive.
