The Sharper Image Oversized Universal Remote Control TV - F3356761
Where can I find a manual
Posted by K Setter on
Russ Shaw
  • 3 Answers
I have This remote did a video on how to scan for channels with your 6 in 1 here it is.
https://youtu.be/B0dNFupTlZg
The Sharper Image Oversized Universal Remote Contr - 3_26_2020_5_31_08_am.jpeg
Posted on Mar 26, 2020
Tom Chichester
    Top Expert:
  • Televison & ... Master
  • 55,375 Answers
Try Googling (Sharper Image)(F3356761)(manual) without parens.
Posted on Dec 12, 2017
5 Related Answers
Anonymous
  • 4 Answers
SOURCE: INSTRUCTIONS NEEDED FOR THE SHARPER IMAGE - JUMBO UNIVERSAL REMOTE
Hello kls1996... programming your remote is rather easy. The easiest way (thanks to The Sharper Image Jumbo Remote being a LEARNING SMART remote) is to do the following:
1 - Point the head of your Sharper Image remote at the head of your Sanyo TV remote (nose to nose so the clear bulbs on each remote are facing each other).
2 - Press the "TV" button on your Sharper Image remote (located in the upper left-hand corner).
3 - Hold the "LEARN" button on your Sharper Image remote (located in the left edge under the volume buttons) until the red light flashes.
4 - Press the key on your Sharper Image remote (e.g. Volume Up or +VOL)... the red light will go solid (indicating that it is waiting for a signal from the other (in your case Sanyo) remote.
5 - Press the key on your other remote (in your case the Sanyo remote) that you want programmed in your new Sharper Image remote... the red light will flash rapidly again.
6 - Repeat step #4 until you have programmed each key.
7 - When done... press the "LEARN" key on your Sharper Image remote. Your Sharper Image remote should be programmed to operate your device (in this case, your Sanyo TV).
NOTE: You can program other devices such as your VCR, DVD, VHS, SAT, CABLE, etc. and not just one device.
Posted on Jan 16, 2009
Anonymous
The "auto" mode isn't quite presented correctly in the documentation or posts I've seen...after MUCH trial and error (and about 3 hous) I've been able to set-up ANY infrared device, either by "auto" or learn. (Although maybe not "fully".)
AUTO Method
1. Press & Hold (about 3 sec.) the [DEVICE] button on the JUMBO Remote....llight will stay solid.
2. Now just press the [POWER] button (only) ONCE while pointing at the device...it will start sending codes approximately every second. (Don't keep pressing the power button as instructions indicate.)
3. TIMING IS EVERYTHING HERE. (It may take 5 minutes to find your devices code.)
4. AS SOON AS the power goes off...press the [ENTER] button on the JUNBO Remote.
5. Now pressing the [POWER] button should power up/down the device.
---- any buttons not programmed will have to be handled using the LEARN method ---
LEARN Method
1. Press & Hold (about 3 sec.) the [DEVICE] button on the JUMBO Remote....it'll stay solid.
2. Press the [LEARN] button on the JUMBO Remote. (light will immediately blink rapidly.)
3. Now Press the {NEEDED} button to program. (light will stay solid)
4. Now (1 to 2 inches away) have the ORIGINAL Remote pointed at the JUMBO Remote and press the {DESIRED} button on the ORIGINAL Remote.
5. It blinks rapidly while sending...then a slower steady blink once "LEARNED" correctly.
*** Not all buttons work properly with the "LEARN method". Some you will need to "associate" with an alternate button on the JUMBO Remote. ***
I sincerely hopes this helps anyone & everyone.
Posted on Dec 16, 2008
pishta68
Steven Wander
  • 594 Answers
..check it out....
http://www.blurtit.com/q717681.html
Posted on Feb 17, 2008
Anonymous
  • 10 Answers
SOURCE: NEED MANUAL FOR SHARPER IMAGE JUMBO UNIVERSAL REMOTE 1613086
The manufacturer of that remote is Emerson.  Here is the manual.
http://mscustomercare.com/forms/JumboRemoteEM_InstructionManual.pdf
Posted on Mar 27, 2009
the q guy
Tony Walker
  • 393 Answers
SOURCE: The sharper image jumbo universal remote jvc tv
I found that this website should have all the codes and instructions for most remotes
http://www.xdiv.com/remotes/
Posted on Jan 04, 2010
Instructions for avon the sharper image oversized universal remote control
need instructions for Avon The Sharper Image universal remote
Feb 25, 2012 | Televison & Video
Tip
Sharper Image Jumbo Remote Manual
Sharper Image Jumbo Universal Remote Control Manual
Have you misplaced your Sharper Image Jumbo Universal Remote Control Owners Manual?
Would you like a digital, searchable, pdf version of the Sharper Image Jumbo Universal Remote Control Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
on Apr 30, 2010 | Televison & Video
Programming
i need codes to jumbo sharper image universal remote
Jan 27, 2009 | One For All URC-9910 LCD Remote Control
Dec 27, 2008 | Televison & Video
I Am trying to program the sharper image jumbo sized universal tv remote.I can;t get the Samsung dvd/vcr combo to except any code listed in the instruction manual
I can help you with your Sharper Image remote control.
There are two Sharper Image Remote Controls: a Sharper Image Jumbo Touch Remote Manual, and a Sharper Image Jumbo Remote Manual.
The Jumbo Touch remote does have a learn function which may be helpful in controlling your Samsung DVD/VCR combo.
I hope that helps.
Sep 12, 2008 | Sharper Image Professional Plus Ionic...
Need remote code for rca dvd/vcr combo using a sharper image univeral remote
Use code search on your Sharper Image remote control to find something that works. If a search through all codes stored in the remote control fails, you may have to try a different universal remote control. All universal remote controls do not contain all possible codes.
Jul 24, 2017 | Televison & Video
Televison & Video Logo
174 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
