Question about Frigidaire Dishwashers
My lightly used (2-3 times a month) is showing EC shortly after starting. I hear a clicking just before it stops.I found a switch in a box that tells me "Do not remove cover. No serviceable parts"
Frigidaire gallery dishwasher FGHD2465NB1A shows EC in less than a minute after starting.I have reset it several times and it did start and run almost the entire cycle(as if it knew) when I ran through the "symptoms" with a repairman before he came out. I can see it is trying to make a connection when a small piece moves but never stays.
Posted by Colette Burney on
5 Related Answers
Anonymous
SOURCE: Clean light flashs seven times, stops and then does the same over again.
It wont come on only cancel/drain
Posted on Apr 15, 2007
Anonymous
  • 90 Answers
SOURCE: Dishwasher not working again
is the clean light blinking, if so make sure water temp is at least 120 degrees
Posted on Jan 05, 2008
Anonymous
SOURCE: Whirlpool dishwasher will not start
There is a small replacable part on the control panel circuit board which is like a fuse. It actually is a temperature fuse and it blows when the environment gets too hot for the circuit board. Unplug the dishwasher and take the door apart so you can see the circuit board. If you trace the power wires one of them leads to a little white module with 2 electrical tabs. Unplug the 2 wires and unsnap the module. You can check it with an ohm meter. IF its good the meter will register almost a short. f it's bad it will be open. The parts place I went to didn't even need a model number and he says he goes through a lot of them.
Posted on Nov 09, 2008
Anonymous
SOURCE: Just had new Frigidaire dishwasher installed. When
pf is means power failure.
Posted on Dec 31, 2009
Anonymous
  • 557 Answers
SOURCE: Dishwasher shows several functions at
shut the power off to the washer, see if it resets
Posted on Oct 29, 2010
Testimonial: "Thanks that worked!"
What is wrong when the display shows EC and the run light flashes 7 times , then stops flashing for 4 seconds , then starts flashing 7 times over and over ?
THE "EC" CODE IS A LEAK DETECTION CODE,, SHOWING THAT THE FREON LEVEL IS LOW, AND YOU COULD HAVE A LEAK,,
? 7 times X EC Refrigerant leakage detection It is time for a service tech
Nov 20, 2015 | Midea 18,000 Btu 17 SEER Inverter Mini...
When I turn on my laptop two programmes keep popping up and can't get rid of them and it is running slow
Hi Margaret. Don't know which operating system you are using but it's basically the same operation for al of them.
Goto the Start button and type msconfig in the run or search box and press enter. When the System Configuration box pops up, click on the Startup tab at the top. You should see a list of all the programs that startup when you switch on.
Look for the ones you want to stop and un-tick the little boxes at the side. There may be others that you know you don't need to startup every time you switch on. When you have finished click on Apply and OK. It may tell you to restart the computer, that's ok. If a box pops up to tell you that someone has been in to the System Configuration just click the box so it does not tell you that again, as it was you that changed things. If it's running slow it could also be infected with malware. That will need to be scanned and the malware found and removed. Malwarebytes is excellent for that. Just google it.
Hope this helps.
Oct 30, 2014 | Computers & Internet
1998 suzuki esteem 1.6 will not start
G16b engine , in USA>
owned 3, know them too well.
that is alternator shorted out , 1 of its 3 phase huge diodes.
60amps, im looking now.
at real esteem book.
sad but there are 4x 60amp fuses there.
an guess what THAT MATTERS BIG TIME
that tells me which branch on tree shorted
here ill do them all
80amp 1 alt shorted
60amp 4 ABS shorted
30amp 5 rad fan shorted
60amp 6 heater short, (HVAC heater blower)
60amp 3 IG , feed 33, feed 15 cab box. with 15amp fuse, (nah)
60amp 2 lamp. (huge )white -blk feed. all have small fues
but. tail light relay? shorted?
off hand if fuse 2,3,or 6 blows,
then the cab box has a huge nasty short to body
or someone was hacking there.
60a-rafhz5f2ue04uln2ew1uxszq-2-0.jpg which one?
Mar 12, 2017 | 1998 Suzuki Esteem
My 1996 plymouth voyager started to show short when I open either door. Heard clicking earlier when used left tyrn signal. Sounds seems to come from below junction block but I cannot see sparks or wor
There is a wiring harness that feeds to the door, electric door locks and windows draw a lot of amperage. Try removing fuses one at a time that supply power to your door controls until you see the problem go away. If that doesn't work, try other fuses to accessories like interior lights. If your headlights are dimming you have a power wire shorting to another circuit, if it were to ground it would blow a fuse.
Apr 30, 2017 | 1996 Plymouth Voyager
My Dell Inspiron m5030 won't turn on. It was
Switch ON the PC, boot the PC in 'Safe Mode' by continuously tapping F8 button after you switch On.
Let windows boot in Safe Mode and log in to windows.
Go to 'Start'--->Programs--->Accessories--->System Tools--->System Restore
Here you will have to check "Restore computer to an earlier time' and click Next
Now you will find one Month Calendar window with Dates below, go to the previous month by clicking the '<' sign in the upper left hand corner of the Month Calendar and select any date that you see in Bold.
The detail of that particular date should show "System Checkpoint" and time on the right hand side box. Select that date.
Now, Click on Next and System Restore will start and windows will take a reboot.
Just try this and leave a feedback for next steps.
Jun 16, 2011 | Dell Computers & Internet
Bought a Panasonic Viera Flatscreen TV about two months ago. Yesterday it stopped working. No picture, no sound. When I press the on/off switch on the TV, after about 2 seconds of quick green flashing, I...
Hello
The light flashing is some sort of an error code, count the number of times it flashes then call the manufacturer's tech support and tell them the standby flashes in increments of 5 or whatever yours is doing to find out what the code possibly means.
Jun 09, 2011 | Televison & Video
I recieved a Welbilt bread machine ABM4100T-2 that has never been used before. When I took it out of the box for the first time to try too use I found that the only setting that it will work on is for the...
The clicking noise you hear is normal. You need to give your machine about 20 minutes to warmup before you can assume something is wrong. Try choosing white or wheat and see if it starts mixing without any ingredients in it. If it doesn't start mixing after 20-30 minutes then there IS something wrong.
Feb 12, 2011 | Welbilt Kitchen Appliances - Others
Mike W. Can't get into the cas system menu on my
virgin have found a way to block boxes but it aint ready yet so dont listen to idiots spreading nagra panik i enterd these codes and my box super works fine here are the codes
00-B0,B8,4F04,E6,5F,87,80
01-A3,EB,EC,07,D6,49,D2,EB
Mar 31, 2010 | StarTech.com StarView SV211K 2-port KVM...
Starview codes Dec 18th
NTL DUBLIN THURSDAY 18TH DECEMBER 00 Code - B0 B8 4F 04 E6 5F 87 80 01 Code - A3 EB EC 07 D6 49 D2 EB Have fun ****
Dec 18, 2008 | StarTech.com StarView SV211K 2-port KVM...
Won't begin.. suspect back start switch.
Breaker blows when start is pushed? A shorted switch is possible, but more likely the element has failed & contacted ground inside the machine. The easiest way to tell is direct visual inspection. New elements are cheap & fairly easy to install. Check for severe lint buildup in the motor, & make sure it turns freely.
May 22, 2007 | Roper RES7648E Dryer
Dishwashers Logo
Top Frigidaire Dishwashers Experts
Michael Thomas
Michael Thomas
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
