U have used Qsee, Swann and Lorex. I have a PTZ that has worked on several systems. There is a set-up for the actual PTZ camera which you appear to be aware of. The App or program you are using has a set up for a PTZ along with on screen controls for it in the program. If the DVR you are using is not PTZ ready there is your answer. Should have a 2 wire acceptors one negative one positive.
The movement you are seeing initially, are the PTZ powering up and self testing. What brand DVR are you using, and is is compatible with your PTZ camera?? LOL Swann Tech Service said my Lorex PTZ wouldn't work with my new hi-res system. Well it does...
I will try to look for your reply to continue to troubleshoot for you.
Cheers,
Chance
San Diego, CA
Testimonial: "I'm using a floureen DVR and it is rs-485 ready. Or ptz ready. I've matched all the setting to the bracket pelcod 2400 baudrate then 8 and 1 and none. But still no movement I've tried the onboard controls I'm wondering if I still need a external joystick controller"
SOURCE: replacing oil pump in 95 Cutlass 3.1L
YOU WILL HAVE TO REMOVE THE EXHAUST PIPE IN THE REAR.IT HITS THE FLOOR PAN.ALSO REMOVE THE TWO DOG BONE MOUNTS ON TOP IF THIS ONE HAS THEM
SOURCE: reversed polarity while jumping lexus sc430..HELP!
its very possable the ecu is damaged, but you will need to check all the fuses and or fuseable links
SOURCE: 2002 buick lesabre won't jumpstart. Car ran fine
There are a couple of factors here:
Hope this answers your question and gives you a good place to start. All the best.
Greg
Before servicing the vehicle, refer to the Precautions Section.
Disconnect the battery ground (negative) cable from the battery.
Raise and support the vehicle.
Remove the radiator air baffle.
Remove the starter motor BAT terminal nut and electrical leads.
Remove the starter motor bolts.
Remove the starter motor.
Starter motor mounting-3.6L engine
To install:
Install the starter motor.
NOTE
Use the correct fastener in the correct location.
Install the starter motor bolts. Tighten the starter motor bolts to 37 ft. lbs (50 Nm).
Install the starter motor S terminal electrical connector.
Install the battery positive cable and the BAT terminal nut to the starter motor BAT terminal. Tighten the starter motor BAT terminal nut to 115 inch lbs. (13 Nm).
Install radiator air baffle assembly.
Lower the vehicle.
Install the battery ground (negative) cable to the battery.
Before servicing any electrical component, the ignition key must be in the OFF or LOCK position and all electrical loads must be OFF, unless instructed otherwise in these procedures. If a tool or equipment could easily come in contact with a live exposed electrical terminal, also disconnect the negative battery cable. Failure to follow these precautions may cause personal injury and/or damage to the vehicle or its components.
To install:
