First check, in there a room thermostat fitted. If not look at the boiler timer if a circular clock type move the side slider to gentral position and set the timed pins do that when the clock face rotates the pins operate the boiler heating on switch OR if a digital type press the button marked mode to so that on the display there indicator bar moves to the on position.
SOURCE: wiring diagram worcester 24i junior
http://www.worcesterbosch.com/ gothere and see iu get help for what you want.
SOURCE: Worcester combi boiler losing pressure & water through o/flow
having the same problem and its a new bolier. thanks , adriano.
SOURCE: worcester greenstar hot water fluctuation
the limit stat could be out of calibration, low water rate, by/pass if fitted may need reculated, could be blocked heat exchanger best of luck
SOURCE: My boiler is not working, not heat, no hot water,
your condensation pipe may be frozen get a hairdryer on it or a hot kettle that should sort it thats the whit pipe on the left usualy plastic
SOURCE: Worcester Bosch Highflow 400 Boiler - no hot water or heating
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Hi, this is Worcester, Bosch Group
Although we don't currently offer live technical support online, our Technical
Support department will be able to help. Their number is 0844 892 3366 -
they're open 6 days a week and on average answer calls within 20 second. If you
want to know more about our Technical Support department visit our website
http://www.worcester-bosch.co.uk/homeowner/customer-service/customer-technical-support
We look forward to helping you
