SOURCE: webcam problem /windows vista
WRONG .... i wish people did research before thinking they know everything ....... and its not Vista more of Labtec, with certain old usb labtec cams, they decided to stop all support on them, there fore the latest drivers from labtec for vista may mean it wont work. There are ways around it but u need to be lucky and find drivers which are version 6 or below first for it to work.
SOURCE: how to get labtec webcam to work on msn live?
We couldn't start your camera device. Please check that your camera is not currently in use by another program, and then try again.
this is the error msn i get when iam trying to use my camera in msn messenger on all other i can use ? whats the reason ?
SOURCE: Trying to install Labtec drivers for my labtec
You can contact Labtech from here
http://www.labtec.com/index.cfm/service/splash/AMR/EN,CRID=3
You may have to run it in Compatibility mode if Windows 7 webcam software is not available - I'm sure they can advise you
To navigate to CM on my logitech I rightclick the webcam shortcut icon on the desktop and click 'Properties' and then the 'Compatibility' tab.
SOURCE: I'm looking about the drivers for al labtec webcam
Copy on this site and paste it in your web browser
http://www.labtec.com/index.cfm/service/listing/EUR/EN,crid=68,crid2=1764
to down load Labtec Camera Drivers.
Then do this.
Disconnect the Camera from the USB port and reinstall the CD or Downloaded software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Then to use it on the Web, do this.
Web Camera's have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/ )
set it up as follows:
Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
Then click on the Video Settings.
The camera, if Installed Properly, it will come up and show a video picture.
Then, on the bottom of the page click save.
The camera and audio should function properly. Your friends and Family will now be able to see and hear you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.HTML )
Go to Messenger at the top left and click on it.
Next go down to Preferences and click on it.
Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
Next go to the Test Audio section and (in blue writing) click on "Open the call setup assistant" and follow the instructions on the left window.
C. Windows Live Messenger:
http://www.microsoft.com/downloads/details.aspx?familyid=d78f2ff1-79ea-4066-8ba0-ddbed94864fc&displaylang=en
After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
Then on the Windows Live messenger window on the right side, click on " "Show Menus." And then click on "Show the Menu Bar".
Next go to the Menu Bar on right side, click on " "Action."
Go to "TOOLS" and click "Audio and Video Setting" and follow the instructions.
NOTE: Your audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
D. AIM (AOL) Messenger:
http://dashboard.aim.com/aim
On the VIM sign-in window, click on Edit.
Then click on Settings Enhanced IM.
Next click on Enhanced IM.
Then click on Audio Video.
The Audio and Video portion has drop downs so you can select the proper audio card and video camera installed in you computer.
The Audi Video drop downs are
Microphone
Speaker
Camera
The audio and camera should function now.
Additional information to use with VIM settings.
Adjust Your Audio and Video Settings:
In order to adjust your audio and video settings, please follow the steps given below:
1. Click the Audio and Video Settings button directly below the My Buddy or My Camera window. If you are currently
Participating in an AOL Live Video IM session, a message will display: You must disconnect the current AOL Live Video IM
conversation before running setup. Would you like to disconnect now? Click the Yes button.
2. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working
Properly. Follow the on-screen prompts.
Notes:
The first time you use AOL Live Video IM, a message will display: Would you like to first check your audio and video settings? Click the Yes button.
The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working properly.
images in AOL Live Video IM may appear reversed, or as a mirror image (text may appear backwards) when you look at your own camera feed or at the
Picture-in-picture (PIP) display.
After making the settings your ready for a chat and video talk with your Family and Friends. Hope this helps. Bud
SOURCE: i need to update my labtec webcam/mic driver to
First check the labtec website to see if they have a Windows 7 driver for it.
If not, it might be that Windows 7 supports the webcam directly, but I guess you have tried that.
Last option is to look for a compatible webcam driver for Windows 7 which is not from Labtec. This is possible since Labtec uses third party webcam components. Try using a driver finder application for that.
