Question about Ultra Computers & Internet
I have just bought a 49 ultra hd but I have to have the volume up in the 70s to hear it, is there some way I can adjust volume control
Posted by Lorna Edwardson on
2 Related Answers
SOURCE: insigna HD-LCD 32': can not
try taking the batteries out press every button then install a fresh set of batteries. If this wont work try contacting www.remotes.com
Posted on Oct 08, 2008
gopakumarg43
  • 76466 Answers
SOURCE: my bauhn 49 inch 4k ultra HD smart tv races over all menu items what can be causing this??
Do a reset to this TV, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Posted on Aug 27, 2017
Tip
GSM alarm system with RFID & APP control and Touch keypad
Name:GSM alarm system with RFID & APP control and Touch keypad
Memo:
products introduction
??Features:
??Multi-languages voice; system volume is adjustable (low, medium and high);
??99 RFID cards to arm, disarm, and control the relay;
??SMS notification for disarm by RFID card; SMS content (of the first 10 cards) is editable;
??12-second voice message: by control panel or remotely;
??Broadcast system time and play voice message;
??Use panel as a telephone to make calls;
??Set the by control panel, SMS or remote calls;
??10 remote controls, 99 wireless and 2 wired defense zones;
??Sensor low power alert and tamper alert;
??Some of SMS alarm contents are editable;
??SMS alert for control panel tamper, low power, power failure/ recovery;
??Remotely control the relay.
REV M White SUNRAY 800 HD SE SIM 2.10 Card SUNRAY DM800 HD SE A8P ALPS M Tuner SUNRAY DM800 HD PVR SIM210 with Wifi HDMI SIM 2.1 Cable receiver.SUNRAY DM800 HD SE A8P card SUNRAY DM800 HD SE A8P card ALPS M Twin Tuner SUNRAY DM800 hd Pro Alps Tuner REV M SUNRAY DM500 hd Pro satellite Receiver ,wholesale cheap discount price.alarm security systemVU SOLO 2 SE Twin tuner SOLO MINI 3LED DisplayLED signLED Display ScreenOUTDOOR LED sign large LED DisplayOUTDOORLED SIGN BOARLED DisplayFlexible CurtainLED Dance Floor Display FullCOLOR OUTDOOR Led Sign led screenoutdoor led displayled displayindoor led displaytransparent led displayled display lightingled video wallchina led displayfull color led displayled screensflexible led screenrgb led displaylarge led displayled curtainled dance floorfull color led displayout door led displayled display manufacturerssmd led displayled dance floor for saleled display, led curtain, led mesh for stageoutdoor led screenadvertising led displayindoor led displaystransparent led screenled meshled displayled screenA8p card SUNRAY SR4 V2 Rev.E jynxbox store
dreambox dm800 hd se v2alarm security systemdreambox dm7080dreambox dm7080dreambox dm820dreambox dm7020 hd v2cheap wholesale dreambox dm800 hd v2Sunray SR4 V2 Sunray SR4 800 se Sunray SR4 hd se JynxBox Ultra HD V14JynxBox Ultra HD V16JynxBox Ultra HD V15Dreambox DM7080 HD PVRDreambox DM820 HD PVRDreambox DM8000 HD PVRDreambox DM7020
on Mar 29, 2016 | NU -set Gsm Padlock Alarm System -...
Sky remote control code for samsung ps43e45/49 tv
The code you are looking for is 1340. I have the same TV and my sky volume hasnt worked since I bought it, (9 months ago).. After spending an age on the SKY forum with no luck, I simply googled (Sky remote codes) and clicked on the 1st site, it's skyremotecodes.co.uk then Samsung 6000 series.... It told me the correct code and gave me clear instructions...... I hope this helps someone else.
Aug 17, 2012 | Samsung TV Remote Control
Kenwood receiver speakers static pop
Your volume emitter needs to be replaced. And or the resisters on both sides of it.
Apr 18, 2012 | Kenwood Kr-5600 Vintage 70s Am/fm Stereo...
I just bought a 32 in samsung tv.. the audio worked fine until I had the cable guy come and install the cable box on it.. Now I turn it all the way to 100 and still can't hear it very well.. any...
Try adjusting the volume on the cable box. The cable box should have a on-screen volume control, try setting it up some. You may have to navigate around to find where you control the cable box volume but it should be there.
Mar 08, 2011 | Televison & Video
Downloaded skype. I can receive and hear the calling party, but they are unable to hear me.
This is the issue regarding the Internal Microphone in the Computer.
Your contacts cannot hear you, until you have enabled the Microphone in the Computer.
You will find the information to enable the Microphone below:
Windows XP:
1) Double-click on the Volume Control. 2) Select the "Properties" option from the "Options" menu. 3) Select the "Recording" option in the "Adjust volume for" section. Click the OK button. Check the box labeled "Select" under the microphone volume and you should now be able to adjust the volume for the microphone.
Windows Vista:
1) Right Click the Volume Icon at the bottom right corner of your screen [The Task bar]. 2) Click [Playback Devices]. 3) Right Click the [Speakers] Icon and click Properties. 4) Click the [Levels] Tab; and there you will see the Microphone Volume slider (The one at the very bottom of the "HD Audio output" and "PC Beep" sliders where you can un-mute the mic playback.
Windows 7:
1) Click on Start (the Windows icon) and type sound. 2) Click on Sound under Control Panel. 3) Click on Recording tab. Select Microphone and click on Properties. 4) Click on Levels tab. The default Microphone Boost is set to 0. Increase it. 5) Close all the dialog boxes, and the microphone will be ready for use.
Hope this helps.
Jul 07, 2010 | Toshiba Satellite P105-S9337 Notebook
Acer 7530 Volume problems
Click start menu and go to control panel. Look for sounds and audio devices. Adjust the volume to your desired percentage volume. Or if you can see speaker icon on task bar double click it and you can access wizard. Adjust volumes of different components...
Jul 09, 2009 | Acer Aspire 5100 Notebook
Need to know how to adjust volume on bluetooth
by pressig the volume button up and down
on the handset press the volume buttons
any thing else idont know
Mar 25, 2009 | Motorola Mobility H350 Wireless Headset
Sharp Aquos LC-26D4OU HDTV volume adjustment problems
I found that the problem was also with my HD box. I was able to turn the volume up on the box.
Mar 02, 2008 | Sharp Aquos LC-26GD4U 26 in. LCD HDTV
Computers & Internet Logo
140 people viewed this question
Top Ultra Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Marvin
Marvin
Vebble
Are you an Ultra Computer and Internet Expert? Answer questions, earn points and help others
