Computers & Internet Logo
Jerry Holloway Posted on Dec 09, 2017
I cant get my palm to sync with my desktop - Palm Computers & Internet
5 Related Answers
Anonymous
  • 473 Answers
  • Posted on Sep 11, 2005
SOURCE: Cannot hoysync with outlook 2003
After installing, reinstalling, deleting, hard resets, hitting head against wall... I tried installing the Pocket Mirror conduit as a last ditch effort. An error message popped up saying it could not find the mapi32.dll file. I looked at another PC, located that file in the windows32 directory, copied it to my PC, and I was able to hotsync with Outlook. To test this, I uninstalled the Pocket Mirror and Palm desktop SW, then deleted the mapi32.dll. Installed the Palm 4.1.4 sw, outlook 101 update, plus the conduit update, had same error messages. Added the mapi32.dll to the windows32 directory - was able to successfully sync with Outlook!
Anonymous
  • 7 Answers
  • Posted on Oct 30, 2008
SOURCE: Hotsyncing Z22 device with Palm Desktop
Check what is the action set to address book (contacts) conduit in the HotSync manager in System tray, make sure that it is set to "Synchronize the files" or you can change it to "desktop overwrite handheld" then perform a Sync.
Bubbabear64
Tim Babcock
  • 2794 Answers
  • Posted on Dec 27, 2008
SOURCE: Can I sync an Ipod touch with my Palm Desktop for windows?
I don't believe that the Palm desktop manager is compatible with Ipod. Unless you have your contacts associated with Microsoft Outlook, that should work.
Joed911
JDTec
  • 4338 Answers
  • Posted on May 21, 2009
SOURCE: Transfer data from Palm Desktop on iMac to iPhone 3G
Try the steps on this link:
http://edweirdo.blogspot.com/2009/05/palm-to-iphone-migration-guide.html
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Anonymous
  • 51 Answers
  • Posted on Aug 06, 2009
SOURCE: Syncing Palm Centro to Palm Software
Export your contacts out of Palm as a CV file then import them back into LotusNotes
I cant sync m150 with W 7
HP, Palm's new owner, has offered
Palm Support Palm Tungsten E2 Palm Desktop 6 2 and HotSync Manager... to help sync PDAs to Win 7. However it lists the z22, which used Palm OS 5.4, rather than the m150, which used Palm OS 4.1. I don't know if that will provide a barrier, but good luck in your attempt.
1helpful
2answers
Putting contacts on the SIM card
When I migrated from my Palm Centro (best smartphone ever) to my current BlackBerry, I did the following: 1) Export Palm contacts from the Palm Desktop software to CSV (comma separated values or tab-delimited text) format. 2) Import the CSV file to your Google Contacts account. 3) Wirelessly sync Google Contacts to your new phone using the free Google Sync app (link below). 4) Verify data was transferred appropriately.
Google Sync works with iPhones: http://www.google.com/mobile/sync/
You should be able to follow the same process for your Palm Calendar by exporting your Palm Calendar from the Palm Desktop software to a file (save the exported file to your desktop, or an easy to find location on your computer), then import the Calendar file into a NEW Google Calendar, not your primary calendar (in case there's conflicts or problems, you can delete the secondary Google calendar without losing your primary Google calendar items). Google Sync should allow you to choose more than one Google Calendar to sync with your iPhone.
3helpful
2answers
Copy Contacts from Palm Centro to SIM Card
Google Sync details: http://www.google.com/mobile/sync/
You should be able to follow the same process for your Palm Calendar by exporting your Palm Calendar from the Palm Desktop software to a file (save the exported file to your desktop, or an easy to find location on your computer), then import the Calendar file into a NEW Google Calendar, not your primary calendar (in case there's conflicts or problems, you can delete the secondary Google calendar without losing your primary Google calendar items). Google Sync should allow you to choose more than one Google Calendar to sync with your new phone.
How do i tranfer my contacts from my palm centro & another palm centro?
First, make sure you backup all of your data, including data in any 3rd party apps.
Sync your first Palm Centro with the Palm Desktop software to save the data.
Verify the sync settings in the Palm Desktop software to make sure when you begin syncing with the new Palm Centro, the settings for each application (contacts, calendar, memos, etc.) are one-way sync to the device, or you might end up overwriting the data in your Palm Desktop software with what's on the new Palm Centro.
When you sync your new Palm Centro with the desktop software the first time it will ask you to name the new device. If you give it the same name as the old Palm Centro, all of the data will sync to your new Palm Centro.
Search your computer for a folder with the name "Palm" in it to try and locate the name of your old Palm Centro, so you can name the new Palm Centro the same. When you locate that folder on your computer, it would be a good idea to simply make a copy of that folder as a total backup.
I haven't used my palm in a while
If you don't remember the Palm password, you'll have to do a hard reset, which will erase all of the data.
Then, please download the latest Palm Desktop version from Palm.com and install it on your system.
After both of these steps, you should be able to sync.
4answers
Why will my Garmin not sync into my computer?
First, right click the hotsync button in the task bar and make sure "USB" is selected (assuming you're using USB...).
If that doesn't work, let me know.
2helpful
Palm III sync program for outlook 2003
You can get a compatible palm desktop software and install it. it will let you sync again. you can get the palm desktop software from link below http://kb.palm.com/wps/portal/kb/common/article/33529_en.html
Sep 13, 2005 • Palm III
2answers
Palm data and ActiveSync
You won't be able to do that. Lotus Organizer as well as Lotus Notes and OutHook are PIM some plus e-mail, just like Palm Desktop is a PIM. So you can have the Treo sync with Lotus Organizer AND have the Axim sync with it also it is because there are conduits buit for them. There is a middleware that allows both to talk to one. Now if you can find a piece of software out there that will sync a PocketPC with Palm Desktop, I'm sure a lot of Palm converts would love to know that.
3answers
Cannot SYNC Outlook Calendar and Contacts
Probably one of these issues - your data is there but you are looking in the wrong place. I am trying to sync my outlook calendar and contacts via Hotsync on a Palm IIIc. It gives me the status of OK, but nothing shows up on the Palm. I have set the custom on Hotsync to desktop overwrites handheld, but still will not work. Thanks.
Top Palm Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
vince
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
