Question about Samsung Office Equipment & Supplies
My samsung clp-325 is displaying door open on my computer and having the red light on
Posted by felix liberty on
HEMANT GROVER
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Samsung Expert
  • 171 Answers
Front cover of back cover sensor needs to be checked
Posted on Oct 03, 2018
Marie Mc Guinness
Take the toner waste unit out and all cartridges, then take the fusing unit out . turn it to the side and shake all of the waste toner out of the fusing unit( be careful not to bang the fusing units rollers) when this is done blow out the printer and fusing unit( do not put your hands on the fusing unit) and the toner is poisonous , so wear a mask and gloves. the reason the error occurs is because the fusing unit has to much waste toner in it and it can't push it into the waste toner unit, so its getting stuck in the fusing unit and then you get a red light for waste toner unit full when it really isnt full but the fusing unit is. good luck all .hope it helps someone
Posted on Oct 01, 2018
5 Related Answers
Anonymous
SOURCE: samsung clp 300 ser red status light stay;s on cartrigde light
The waste dispenser (next to the toner cartridges) probably needs to be emptied out.  That's what always sets off the red light for me.
Posted on Nov 15, 2008
Anonymous
SOURCE: Samsung CLP-300 Printer has red light on, won't print, don't see any paper jam
I have to open the front panel as though I were going to replace the toner cartridge, but, instead I pull out the toner reclamation cartridge (the gray "L" shaped one to the left of the cyan cartridge) and then put it back in. This has cleared it each time for me.
Posted on Jan 15, 2009
Rafique Mannasaheb
  • 406 Answers
SOURCE: Our Samsung CLP 300 's red light stays on..
Install a smart panel on PC and see the error on the PC screen.
Posted on Nov 02, 2009
pineworks
Clive
  • 4345 Answers
SOURCE: I have a problem with the clp-315. The red light
Hi there
You can try see if this may do it.
Go to Start / Run and type in "services.msc" without quotation marks, then press Enter or click OK.
In the window that opens (Services) look for "Print Spooler" on the right
Right-click "Print Spooler" and select "Properties".
Click on the "Recovery" tab and change all 3 drop-down boxes to "Restart The Service".
Make sure the 2 text boxes underneath say "1" in them.
Click Ok until you are back at the Services window, close it and you're good to go.
Go back into the properties of the "Print Spooler" tab and be sure to click Start to restart the Print Spooler service and it will restart the service immediately.
The Print spooler depends on the Remote Procedure Call (RPC) service. Is this service disabled? Go to services.msc look for RPC. Check state: Automatic
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on May 04, 2010
SamsuTech
  • 113 Answers
SOURCE: Samsung CLP-650N Engine Fuser Inverter Error 3
the fuser and dave home drive got to be repalce.
most likely it has worn out.
Posted on May 13, 2010
Always shows "Printer offline" status (Mac OSX)
Have you installed the printer driver for the selected printer??
Oct 30, 2017 | Samsung Clp-325 Colour Laser Printer
What's wrong when red light is on
Toner, door open, paper jam, error or laser, can be whatever
Apr 25, 2012 | Samsung CLP-310N All-In-One Laser Printer
My samsung clp 315 printer, lights RED and AMBER together when i switch it on.
my samsung clp 315 Red light blinking & in printing a Horizantal line is came in centre of the paper
Jun 22, 2011 | Samsung CLP 315 Laser Printer
All the lights are flashing
When the status LED is flashing red, it means there is some minor error(i.e. the front door isn't latched shut, paper is jammed, etc) or the toner is getting low.
Double click on Smart Panel (the blue S in the task bar...it's installed with the driver) and it will tell you what the error is. For future reference, you can download the manual at our support site: http://www.samsung.com/us/support/downloads/CLP-300
you can also have a look onto the below link
http://answers.us.samsung.com/answers/7463/product/CLP-300/samsung-clp-300-dsl-questions-answers/questions.htm
Mar 17, 2011 | Samsung CLP 300 Laser Printer
Samsung CLP-300 shows red light . what does it
Dear ,
Install a smart pane software from samsung.com and search clp-300 printer and download the software.
Sep 27, 2010 | Samsung CLP 300 Laser Printer
Why is red light on samsung clp- 315 and it is not printing
Does one of these situations apply to you?
The Status LED light is Red and the Toner lights are OFF (Check Smart Panel for message)
  • A Paper Jam has occurred.
  • The Front, Top, or Back Cover is open.
  • There is no paper in the Paper Tray.
  • There is a problem with the Waste Toner container.
  • A major error has occured.
The Status LED light is Blinking/Flashing Red and the Toner light(s) are Red
  • The Toner cartridge(s) that are Red need to be replaced. (Can still be used to print, but quality is unreliable)
The Status LED light is Red and the Toner light(s) are Red
  • The Toner cartridge(s) that are Red need to be replaced. (Printing is not available)
  • The Toner cartridge(s) are not installed properly.
Source: samsung troubleshooting guide for CLP-315
Sep 25, 2010 | Samsung CLP 315 Laser Printer
I have a red light on my CLP 300. I have changed all of the cartridges and the light is still on
hi check all the things that can open on it, like the top section, the rear door, make sure the front is closed all the way this has a clip at top right that goes into a hole make sure that is not broken as it is hard to pull down the front to put new toners in other than that check the leads going to the printer and computer...hope this helps
Jun 28, 2010 | Samsung CLP 300 Laser Printer
Error light is red, and nothing prints
i think your paper sensor is damaged, replace it
red light show : when paper is not present or toner is not accepted, or door open
We have Zero cost solution for samsung -scx-4300, scx-4824/4828
ml-2240,ML 2245, ml 1640. clp 310/ 315, It is working permenently.
Refill cartridge is working for ever. which is running successfully.
also provide other new model reset solutions.
www.nakshatraworld.com
mob: 9713862555, 9893282285
[email protected]
Nov 22, 2009 | Samsung ML 1710 Laser Printer
Lights
to morganjonesp
the big light that on it own by the red button is the power/ status
green- is on and ready to print
flashing green- printing
amber - fault
the other 4 in a line with a coloured label around them are the toner information
no lights toner- OK
light on- toner is low this will work along side the on screen display you get.
when the printer starts up it run a test and these light are check to see if they are working- watch next time you switch it on.
to myersk
does the printer run though its check and finish and then is ready?
if so then the problem is with what you are sending to the printer to be printed
if not then the problem could be a stuck printer part, a open cover, a bit of paper in the rollers or a major problem!
does the on screen control panel not tel you what is wrong?
Jun 18, 2008 | Samsung CLP 300 Laser Printer
Won't complete cycle
we have Samsung color printer, model CLP-500, not working. Please suggest Samsung service centre in India.
Feb 02, 2008 | Samsung CLP 300 Laser Printer
157 people viewed this question
Top Samsung Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Muntejaya Ginting
Muntejaya Ginting
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
